WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
I was going to suggest sparkfun's THAT 1206 board for comparison, but it seems they've discontinued it. Anyone know a ready made equivalent? https://www.sparkfun.com/products/retired/14002
Warning: We strongly discourage the use of balanced-to-unbalanced cables and converters. Doing so will result in significantly decreased analog performance due to the short they present to the output of the dac8 Stereo's analog stage, potentially overloading it and risking damage after long-term use with high signal levels. Warranty does not apply to units with analog circuitry damaged by using XLR to RCA cables and converters.
Too bad... Though an XLR to RCA cable does not necessarily short anything if it leaves unconnected one of the 2 balanced output pins. Some pro devices ( RME's ones for example) are also short circuit protected.
Btw HIFI gear tend to use balanced mode mainly to decrease THD ( cancelling H2 products) and noise, while pro gear uses balanced connections to allow longer runs of cable, and I personnally find a bit ridiculous this typically picky audiophile use of 50cm XLR cables for marginal SINAD improvements. Worse is when you are bound to operate in balanced mode if you want to avoid decreased performance. A good output design should perform the same, balanced or unbalanced.
Most XLR -> RCA cables will have a Pin 1-3 short in them. This is something to be very aware of if adapting an XLR output to an RCA input.
Professional gear should not be bothered, and, in fact, the short is sensed in many cases and used to implement a 6db gain increase for the other polarity.
Why would we need in for the reverse direction, that is RCA to XLR, when you buy the cheap Monoprice interconnect cables, or Ghantaudio's, or pay a little more to get Benchmarks, or March Audio's? I don't know of a good reason for an active device unless someone cannot afford to lose 1/2 the voltage and, or length is an issue.
Active converter? Hmm... well it's just a good preamp with XLR in and RCA out so I guess any XLR-in preamp accomplishes the same. It has a form factor that fits the name tho and a performance better than generic studio gear.
I've used $6 XLR to RCA cables in professional work since I was literally 14 years old, and never had an issue. I have a pair in a drawer somewhere, and I placed a small toggle switch in the strain relief of the XLR that disconnects the 1-3 pin short.
It's insane to pay $90 for an active box, lol. What is even the point of this? I understand in the reverse configuration, where you need to generate a differential 4v signal from a 2v unbalanced input, but this product reads to me as something that like, audio contracting companies can sell to clueless clients just to fatten up their invoices and margins.
I'd wager a simple converter cable would perform quite a bit better, simply due to its simplicity.
I have an Octo 8 Pro and need XLR to RCA for my two SVS SB2000s. I use use the Benchmark Cable that disconnects Pin 3 rather than shorting it to ground, and it seems to work just fine for my subs. Even if that introduces some distortion, not at all sure whatever increment that adds would be audible above the distortion all those bass transducers already have. And I'm sick of buying stuff I have to find an AC outlet for.
Rather than say that It increases distortion, i would rather say you loose the marginal benefit of some distortion cancelation... But nothing to cry mom about as i am tired of reading...
More than a month ago, an old friend asked me, would you measure a Gustard P26 preamp?In fact, I didn't know Gustard was going to launch this product until he asked me.I then contacted Gustard, who said at the time that P26 had not been officially completed. After the official release, I will...
www.audiosciencereview.com
And there are occasions where companies strongly suggest NOT to use the simple passive XLR > RCA converters or cables on it's outputs,like the Topping DM7 for example (and others if I rememberer well).
Well i am seriously considering buying a Topping Dm7, but won t care a damn about the company s warnings and consider them totally ridículous, unless their intention is merely avoiding RMAs.
If the degradation they imply is enough to bring it down to a 100$ interface perfomance (specially if noise is what is affected) why spend for it?
I would measure it if I was you.
Nice to see something that works as it should. For the cost of this you can just about get a Jensen transformer based solution. While it probably is not audible the transformers will have less noise and more distortion better CMRR and of course almost perfect galvanic isolation. Also no power required. I would go for the transformers but it is good to have choices.
With these transformers (even better than the cheapo Neutrik units tested by Amir) you will get a significant increase in distortion and high pass filtering in the low frequency. For Jensen units you will have to pay more than the adapter tested here, for a worse result, worse even than if you simply take the signal from one of pin 2 or 3, and obviously avoiding to short and overload anything.
If long cables several meters long are not needed balanced connections won t bring any significant improvement other than a marginal sinad improvement owing to noise reduction and H2 cancelation. And also a useful trick to increase voltaje swing in headphones amplifiers.
I would use the Topping L50 (headphone) preamp for conversion between RCA <> Balanced (TRS). Price has decreased to EUR 170 and I think is a cleaner solution.
