Neutrik NA2F-D0B-TX XLR to RCA Adapter Review
Rate this converter:
    Votes: 121 82.3%
    Votes: 9 6.1%
    Votes: 14 9.5%
    Votes: 3 2.0%
This is a review and detailed measurements of the Neutrik NA2F-D0B-TX XLR to RCA (and vice versa) adapter. It is on kind loan from a member and costs US $35.
The device feels very solid and oozes quality when you look at the RCA connector:
Neutrik NA2F-D0B-TX Transformer Balanced XLR to RCA Converter connectors Review.jpg
This is a transformer based converter so balanced operation is maintained. The key then is the quality of the transformer. Let's see how it measures.
Neutrik NA2F-D0B-TX Measurements
Let's start with our dashboard of 4 volts over balanced to the device and then RCA out:
Neutrik NA2F-D0B-TX Transformer Balanced XLR to RCA Converter Measurement.png
Ouch! That is a nearly 60 dB hit to our SINAD caused by the large amount of harmonic distortion. Company specs "Max. Input level (@ 50 Hz, 1% THD): -3 dBu." I am not sure how to read that so let's make our own measurement:
Neutrik NA2F-D0B-TX Transformer Balanced XLR to RCA Converter THD vs Level Measurement.png
We see that distortion sets in very early at just 70 millivolts. Let's look at the frequency response:
Neutrik NA2F-D0B-TX Transformer Balanced XLR to RCA Converter Frequency Response Measurement.png
Hmmm. There is no mention of a high pass filter yet that is what we have. That is likely there because the transformer massively distorts at low frequencies:
Neutrik NA2F-D0B-TX Transformer Balanced XLR to RCA Converter THD vs Frequency Measurement.png
I think we know the story and can stop here.
Edit: Here are some additional tests at -3 dBu. Let's start with the Audio Precision APx555 analyzer measuring itself with this voltage level:
We naturally take a hit in noise performance, reducing our SINAD to 115 dB which is still excellent. Distortion is non-existent. Now let's just plug the NA2F-D0B-TX in the analyzer output without changing anything. In other words, we want to see how much it loads down the output of the analyzer:
Wow, look at how it distorts the stout output of the audio analyzer, dragging its SIAND down to 91 dB due to all those harmonics.
To figure out what is going on, I measured the DC resistance of the XLR input of the NA2F-D0B-TX and it is just 46 ohm! No wonder it is killing the performance of the analyzer.
Finally let's measure the NA2F-D0B-TX fully in the loop now:
Before you say "84 dB is still pretty good" keep in mind that your device may distort heck of a lot more then the output of the analyzer and drag you down even more.
Net, net, stay away from such adapters.
I must stay, I am very surprised that a company like Neutrik puts out a product with such poor performance without any direct mention of such. To be sure, good transformers cost money but at least put the buyer on notice that any performance your audio gear has would be obliterated by this converter.
Needless to say, I can't recommend using Neutrik NA2F-D0B-TX converter unless hum is a major problem.
thats 0.548 V rms, so they spec its limits to this level with max THD at 50Hz... whats difficult to read from this?
Because it is not any kind of maximum. It is just a random data point.
Indeed they could have added >50Hz.. That would have made a more complete definition of it its limits.
I think the device is more used to couple lower level devices like musical instruments to the mixer on a podium..
Measuring it at 1 V clearly is above spec. ( 4V I see now..)
from long experience (if one must use a xfmr) - go Jensen xfmrs (or equivalent quality) - or go home...
and just fyi this is a +4 to -10 (dictated by the xlr gender)... they make a -10 to +4 as part# NA2M-D0B-TX (not that you'd want either one)...
They clearly spec -3dBu...
you know when you have a 'made in liechtenstein' mark you know you're getting quality
did I misunderstand something? - wouldn't be the first time...
No, probably I did...+4 to -10 suggests it can handle +4dBm but it just defines the gain difference..
My first thought was: is this thing even genuine?
The second thought: no brand can be blindly trusted.
Asking for good performance at 4Vrms from peanut-sized transformer is silly and doesn't work no matter who build it, be it Neutrik, Jensen, Lundahl, Sowter, Cinemag, ...
