godsmack50
- Joined
- May 6, 2022
- Messages
- 132
- Likes
- 46
- Thread Starter
- #101
oupppssss , I made the mistake , I didn’t pay attention , excuse me , I delete!!!that is the DL200, i believe it's more expensive
I didn’t even know he had released the DAC SMSL DL200, I just saw it !!! Thanks guythat is the DL200, i believe it's more expensive
My sentiments exactly.Come on...
You are wrong about the built in preamp on SMSL and most other DACs. There is no preamplifier in these devices and there are no components for it. This also explains the lack of integration of subwoofer management or crossover functionality, as it is not possible at all.This has been a problem in the audio industry for many years now (since digital became a thing). It makes me rage internally
They have CD players / Streamers with DAC's built in the unit but no digital inputs to use that DAC. Then they release DACs with preamps so I have to pay for DACs now with built in preamps but then they don't have any kind of subwoofer management or crossover etc. features. So now I have to pay for an integrated amplifier or a dedicated pre-amplifier with all these features but guess what they also have built into the same units. Yes you guess it right. DAC's.
There are some good products which have all of these built into one unit but the pricing far far exceeds the sum of all the different components when bought together at the same time the quality of these built in components is just hohum. It's like these companies want us to buy these items separately and pay extra again and again. Either that or there are separate engineering divisions working separate shifts and no idea what they all are doing.
"E30 II is designed for full digital volume control and equipped with an LED display screen. It can be used as not only a DAC but also a pre-amplifier"
Although subjective it can give some ideas how it is to use for instance.. so not pointlessCome on...
I wasn't talking about a specific model either, as it applies to all DAC models from SMSL, Sabaj, Topping and many others.My statement was not for a particular model. Currently I have a Topping E30 II. The product description on Amazon clearly states
Weirdly enough they give different SNR number for them; AL200 107dB and A300 103dB. So it's not impossible that there are some improvements..I think so, since AL200 and A300 use the same amp chip and we assume they have the same performance.
If u need an amp only, you may consider Fosi V3 amp, which has better measurements and cheaper. You can find the review of Fosi V3 here.
If they quote the SNR like that, it seems they make some improvements. That is good for customers.Weirdly enough they give different SNR number for them; AL200 107dB and A300 103dB. So it's not impossible that there are some improvements..
Where did you see that? I have been looking for reviews for this amp for a couple of days
The preamp function is that there are multiple inputs and the ability to switch between them and the volume can be adjusted. Traditional analog preamps incorporate more features, but not necessarily the same.You are wrong about the built in preamp on SMSL and most other DACs. There is no preamplifier in these devices and there are no components for it. This also explains the lack of integration of subwoofer management or crossover functionality, as it is not possible at all.
Only a DSP function (pure software) of the DAC chip is used for volume reduction (please note this term) and it has nothing to do with a preamp at all. This feature can also be deadly for your speakers.
By this definition, any DAC with more than one input and a way to reduce or control the volume would also be a preamp.The preamp function is that there are multiple inputs and the ability to switch between them and the volume can be adjusted. Traditional analog preamps incorporate more features, but not necessarily the same.
