Neumann KH420 Review (Studio Monitor)
Rate this speaker:
    Votes: 2 0.3%
    Votes: 3 0.5%
    Votes: 33 5.8%
    Votes: 534 93.4%
And why do capacitor manufacturers tell you the life of the component in hours and not in how many times it is powered and removed from voltage?
Because there's no single metric that can adequately describe a complex component. By using a conservative rating in hours and designing a system within the intended operating conditions, you can expect to receive the rated lifetime or greater. That's not to say the behavior of capacitor life is actually as simple as a single rating though. This link has some nice information on the topic.
Manufacturers of capacitors will typically provide de-rating calculations or graphs based on their research and field testing. Often times, these calculations are not included in the component datasheet but are instead found in a separate capacitor characteristics document (the reason for this is that there is probably just too much extra information to include in a datasheet).
Only after you'll touch them you'll understand
You can never go back to MDF and plastic :cool:
We've been here before, but chipboard and MDF if carefully selected, can absorb cabinet resonances perhaps better than ringy metallic ones, certainly rectangular box shapes. Genelec arguably get away with it as the enclosures are cast? and curved.
I'm about to return (hopefully if they've survived storage) to a pair of thin-wall birch ply 'BeeBeeCee boxes' which 'talk' like mad on bass notes at anything over a low volume. Part of the design originally, to keep the midrange as good as possible and back then, it worked. As I can't play the likes of System 7 at anything like a spirited volume level (my ears and our neighbour that we want to remain on friendly terms with), it'll probably not matter (I live in hope) :)
And yes PJ, I look longingly at the Genelec 8381As which I guarantee would wipe the effin' floor and then some with almost all 'domestic' speaker confections at almost any price, but I changed direction in my life thirty years ago and the hobby side and lusting after expensive audio kit disappeared in a flash as other commitments came along L)
Genelec makes rectangular shaped monitors using MDF, even most of the 8381 is MDF as only the waveguide and a part of the front plate is made of aluminum, just like the rest of their main monitors lineup. It's actually the same in most of the Neumann monitors (minus the plastic KH80), aluminum front and MDF box.
None of them are aluminum front, it's some kind of polycarbonate plastic they call "LRIM".
The only Neumann monitor with an aluminum front is the all-aluminum KH 120.
