Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 7,556
- Likes
- 9,352
If the NFS can measure the M9
I trust it completely lol
Won't recap feedback theory - I really tried to boil it down, but envisioned that it won't be appreciated here. Only one point. As I said, the system's performance is limited by the microphone. If it starts to compress its output due to overload, the system as a whole gets into run-away mode, the limited output capability of the speaker (as the actuator) completes the mess..
Otherwise, your take on why it won't work is flawed. The room is not part of the feedback loop; one can formulate a theoretical contribution, though, so please go ahead. I speak maths pretty well (better than English, actually) ;-)
I can only be in one position at one time.Straightforward for a single listening position yes.
But what if there are birds chirping in the background?One thing this thread has done for me....is totally reinforce my belief that the best sub measurements are still made out on an empty parking lot.!!![]()
But what if there are birds chirping in the background?![]()
The low resolution of that picture makes it hard to see what the frequency is where the error is passing 1% on the low end. Is it ~40Hz? And wouldn't the SNR be dependent on the speaker being tested? If it had more output down low, SNR and therefore accuracy should increase, right? So how relevant is the inaccuracy for speakers that have such weak output that low?At the extreme low end, because of signal to noise ratio (low loudspeaker output, high noise), the NFS measurements are not very accurate.
Yes, they mentioned that while purchasing VituixCAD. I guess they use NFS with "multi-way" method/module.If the NFS can measure the M9
Maybe because they were all designed without NFSWhy is Finland making so many good speakers?![]()
Yes. The frequency axis starts at 40 Hz. I have attached a high res version of the slide as a zip file in post 755. The forum software automatically down-samples pictures to save storage.The low resolution of that picture makes it hard to see what the frequency is where the error is passing 1% on the low end. Is it ~40Hz? And wouldn't the SNR be dependent on the speaker being tested? If it had more output down low, SNR and therefore accuracy should increase, right? So how relevant is the inaccuracy for speakers that have such weak output that low?
As said before ;-) the system is not only limited by the sensor, the actuator is limited too. Very low frequency, especially close to DC as a slammig door, remains a challenge. As long as people behave, a slamming door should be the extraordinary, though.As said before, an acoustic pressure wave from the door closing passes by listener ears before it can be countered. And according to Meyer, gives is an unnatural sound from the servo control trying to maintain strict signal linearity. Best laid plans of mice and men.
That's the way I saw it too, but didn't really want to get involved in the discussion!The low resolution of that picture makes it hard to see what the frequency is where the error is passing 1% on the low end. Is it ~40Hz? And wouldn't the SNR be dependent on the speaker being tested? If it had more output down low, SNR and therefore accuracy should increase, right? So how relevant is the inaccuracy for speakers that have such weak output that low?
I will call BS on Meyer Sound on this one. Feedback output microsecond by microsecond? That means the control system sampling rate is in the order of 1 MHz.Sure, it takes a mic/sensor that handles pressure.....very well known...old stuff Circa..2000
The door closing scenario Meyer said was screwing up their sensor tech, is anything but theory.
It was a pure observation..... of an unexpected consequence, of the grand marketing claims made above.
Best to hear the door close, .... leave it alone...... and keep the the servo from responding to it.
Noise cancelling headphones are an entirely different animal, without relevance imo..
No noise reaches the ears first, to be cancelled later. Get's cancelled before it gets to the ears.
Noise suppression/countering is on just the noise. There's no servo control trying to maintain electrical signal linearity.
This is from the lecture notes of the Feedback Control Systems class at MIT OCW 16.30 (lecture 20). When the sampling (update) rate of the digital control system is 15× the required system bandwidth, the impact of processing delay on performance becomes insignificant. That means, if the servo sub works to 200 Hz, a sampling rate of 3000 Hz is all it needs.
View attachment 455325![]()
Feedback Control Systems | Aeronautics and Astronautics | MIT OpenCourseWare
This course will teach fundamentals of control design and analysis using state-space methods. This includes both the practical and theoretical aspects of the topic. By the end of the course, you should be able to design controllers using state-space methods and evaluate whether these controllers...ocw.mit.edu
Dark, cold, not much else to do?Why is Finland making so many good speakers?![]()
Well, there were some ideas, but the government increased alcohol tax.Dark, cold, not much else to do?![]()
