We have that in UK and almost all our speaker companies went broke and got bought by the Chinese.Very expensive beer?
I'm pretty much sure that the feedback is analog, because at least the woofer is analog. To say "from attosecond to attosecond" is just saying, not to be taken literally. It's legal in common conversation.That has always been the Meyer modus operandi: a superficial appeal to engineering and evidence that falls apart with scrutiny. Ditto ATC, Harbeth.
I will call BS on Meyer Sound on this one. Feedback output microsecond by microsecond? That means the control system sampling rate is in the order of 1 MHz.
One of the most tiresome trends on ASR right now is perhaps, ironically, this rise of technically-proficient yet pedantic, dogmatic and nihilistic users that tend towards an overly stringent definition of technical merit than evidence supports.
I asked ChatGPT:Why is Finland making so many good speakers?![]()
While you highlight the pain points well, there are some more remarks.I will call BS on Meyer Sound on this one. Feedback output microsecond by microsecond? That means the control system sampling rate is in the order of 1 MHz.
This is from the lecture notes of the Feedback Control Systems class at MIT OCW 16.30 (lecture 20). When the sampling (update) rate of the digital control system is 15× the required system bandwidth, the impact of processing delay on performance becomes insignificant. That means, if the servo sub works to 200 Hz, a sampling rate of 3000 Hz is all it needs.
View attachment 455325![]()
Feedback Control Systems | Aeronautics and Astronautics | MIT OpenCourseWare
This course will teach fundamentals of control design and analysis using state-space methods. This includes both the practical and theoretical aspects of the topic. By the end of the course, you should be able to design controllers using state-space methods and evaluate whether these controllers...ocw.mit.edu
Amir's next shed…If the NFS can measure the M9
I trust it completely lol
My first post and registered just to say thanks to Amir for the test of the LS1 and to everyone contributing to the thread - I learned a lot. Like many, I’ve always wanted to see beyond the manufacturer’s published data - Grimm has put out a decent amount of data and they are always consistent with their marketing. I landed on the LS1be/SB1 for my home listening enjoyment (a fool and his money), and so far they’ve been great. No objective data to share…yet. But I trusted the process (toe-in, time delay, positioning after positioning) and found a pleasant listening experience surpassing what I achieved with previous setups - all personal attributes, and I think they look cool and have high WAF.
Thanks! The opinions that were shared that drew attention from the datapoints were very much real (at least in my room) in terms of bass output/reach were the challenges I experienced here in my home. But after working to address them as best I can, to me, it is a sound that is more presenting, instant and where things are not overly emphasized.Despite a lot of differing opinions in this thread, I think you can rest assured that you have a pretty good setup with the Grimm!![]()
The LS1 were kind of tricky to finally demo (amongst the other good ones; kii, dutch&dutch, ggntkt) not so much in the way that they are bespoke or exotic-unobtainium passives - they are far from that…they’re in the field and was hoping to avoid visiting a recording studio which obviously does not emulate a domestic space let alone intimidating. Though funny enough, this setup would be more at home in a studio. I also wanted to see how it could be conveniently controlled (MU1) and what limitations/enablements were designed with it so waiting patiently to do so was a long time to endure. But thanks!Lucky you! I’m sure I’m not the only one who envies the fact you own the speakers!
There is an interesting Stereophile review with Eelco Grimm: https://www.stereophile.com/content/grimm-truth-eelco-grimm-grimm-audio-page-2
by pushing the baffle step much lower, the wide-body format enables reduced sidewall interaction down to a considerably lower frequency than would be the case with a narrow-faced speaker.
I found Eelco Grimm's explanation for why 40 degrees of toe-in worked well with his wide-body speakers to be quite educational.
Briefly, by pushing the baffle step much lower, the wide-body format enables reduced sidewall interaction down to a considerably lower frequency than would be the case with a narrow-faced speaker.
Thanks for the link!
…. or a Geithain RL 921K or a Geithain RL 901K!Isn't this just a two-band with a near-field subwoofer, like Genelec 8350 and 2 pcs 7370?
What is their maximum direct sound distance in the mid-high range?
Wouldn't it be preferable to have a Neumann 420 midfield or similar Genelec from 3 m.
