Neumann KH420 Review (Studio Monitor)
Rate this speaker:
    Votes: 2 0.4%
    Votes: 3 0.5%
    Votes: 33 5.8%
    Votes: 529 93.3%
FWIW
I never turn mine off.
The KH 420’s have been on for over 5 years.
My ATC’s in my HT have been on for 20 years
Keeping all circuits from being shut down prolonging the life of the components
Hi
Past week I acquired a pair of 420 , I love them.
But I have noticed that on one unit when you turn it on it makes a mini pop sound.
is this normal?
On the other unit it doesn't sound as loud but it does.
The sound is fantastic on both units, but I'm afraid this will damage the speaker.
I turn on the speakers with all the volumes at zero, I have also changed plugs and power wiring, the same speaker always does it.
If you're located in Europe and using schuko plugs, try reversing the plugs in their socket (swapping phase and neutral connections). In my case, it helped. Initially, I had a small pop every time I turned on the units. Then, after doing the final cabling, observing the correct phase connection at the IEC input plug, it went away. Now, they are completely silent at power on. Hope it helps.
This is the sound I'm referring to
That sounds as if a preamp relay is going off then power up pop. Is your preamp already on .? 420 turned on last ? I would just leave it on . Do they still do it when coming out of sleep mode when signal is applied?
FWIW
Wow, you are burning 120W idle power 24/7 for 5 years just because of a hypothetical longer component life?
This means around 5,000 kwh - in my country between 1,500 and 2,500 EUR.
thank you so much!
I'll try it this afternoon
No
the speaker is off and only does so when I turn it on.
It’s only about €400 for me. Or less than €7 per month.
What is your point?
What is your point?
My point is that if you don't live in a country with clean and cheap energy - like Canada or Norway -, it is not a good idea leaving devices with 60W idle power consumption per piece on 24/7 if you are not using them.
What components life is it lengthening? Hours at temperature takes a toll on things.
I would think relays would be the biggest issue. I don't know if ATC does a standby/ sleep mode but thought it was EU law on such components. Mine coming out of sleep mode definitely fires off a relay.
Lots of failures I find are actually in the standby circuit itself because it remains powered all the time. If it doesn't have standby then I find failures in the hottest area or with the lowest quality/lowest rated capacitors.
If you are using it 12 hours a day you could keep it on 365 days a year and only have 4350 hours of extra of 8760 total on time but you would have avoided 365 on and offs or heat cycles.
If you are using it 8 hours a day and you turn it on and then off each time you'd only rack up up 2920 hours a year. You would have had 365 on and offs or heat cycles though.
It all depends what is going to fail first in the design. Anecdotally I mostly have issues with power supply/standby sections of devices, including active speakers and other professional audio equipment found in studios. Within that it is mostly due capacitors deteriorating. Once those get out spec sometimes the device fails to operate without damage. Other times the added stress in the circuit will cause the power IC, mosfet and other components in the circuit to blow out.
My O410 have some sort of power saving mode in them. I turn them off though as I use them a few times a week.
I basically do the same. I switch a power strip off for anything other then my days off which I tend to leave on in standby.
I also leave mine on all the time. They aren't biased very far into Class A, they idle at pretty reasonable temperatures without much power draw.
Just saw this on Reddit
A pretty cool setup
Hello everyone,
having been reading this forum for some time now, this is my first post and hopefully it will be of value for one or the other. It's about the installation of my KH 420 (more precisely its predecessor model O 410) in my listening room:
I operate the analog O 410s together with two digital KH 750 subwoofers for the following reasons, even though this does not increase the overall volume (closed 10” bass speaker for the KH 750 versus open BR bass speaker for the O 410):
1. Positioning the subwoofers close to the wall reduces cancellations.
2. Positioning the O 410s away from the wall improves localization.
3. Using the KH 750s makes it possible to employ the MA 1 calibration software with excellent results.
My listening triangle is 190 cm (6.2 feet). I have always been very happy with my Neumanns but this configuration is the best so far (in my listening room).
Hello everyone,
Very nice setup. I've got O410s as well but with two KH810. I got to hear some KH150 with a single KH750 and found that the 750 sounds pretty good. The pavers for stands fit in well aesthetically.
FWIW
Which type of component lasts longest if constantly in operation?! Did you know that capacitors have a useful life based on hours of operation?!
Capacitors wear significantly more from the on/off surge than idle, so it depends how often you would turn the speaker on/off. Here’s a general discussion of why amplifiers are often provided with a standby mode that keeps capacitors charged while shutting down the components. I’m sure someone will have a more technically enlightening source.
