Neumann KH 150 Monitor Review
Rate this studio monitor
    Votes: 0 0.0%
    Votes: 4 0.7%
    Votes: 50 8.3%
    Votes: 550 91.1%
In fact, I think that the 6.5" 150 is definitely not as good as the 10" 750 in terms of volume at 40hz-120hz, and the addition of a subwoofer will make music at 40hz-80hz more subdued and more audible. For example, the 11be and 420 are both 10" boxes their low frequencies and sense of scale in the soundstage must be better than the 6.5" 150 and 8" 310.
That may seem like it would be but it is not. Study the measurements. The KH150 needs no help at 40 Hz. The KH 750 adds nothing above 40 Hz that the KH 150 does not already do. I have them and have listened. But more importantly, this is ASR - as in Science..... Study the measurements.
extra subs will lower the distortion in the bass frequencies, and if there is more than one sub, the room modes will also be less deep (without room correction) so the bass will be more consistant.
With the 120 a sub is needed i think, with the 150 very nearfield (on a desk) it is not, from further it can help, but without sub in a not to big room, the KH150 has enough bass to give decent volume on those frequencies. The 310 is more like the 120, but can play louder and only a bit lower. A sub will help, but for a lot you can get away without.
I think more important in the case of the OP will be room correction. As far as i know the KH120A does not have dsp, while the KH120II has. So a KH120II with a pair of KH750 subs and MA1 room correction could be what the OP want. The DSP with room correction can do a lot to make the sound more neutral, also in the bass frequencies where the KH120A lacks.
Also using subs and highpass-filtering the monitors will reduce the multitone distortion on those which can be audible, especially when they are 2-way systems.
Just a slight caveat to the above.
1. KH150 and more so 120ii don't have that much SPL capability in the deep bass region; so dynamics will be potentially reduced in that area, especially once you leave near field. Adding a sub or two helps.
2. More bass sources = less pronounced room nodes is true. But depending on the situation it's not that relevant.
a. You can get a good bass response at the listening position already. It becomes an issue when you have multiple listening positions like in a home theater.
b. I don't think you're getting more bass sources with MA1. With one sub, you are getting one bass source below the crossover point and two above. With two subs, you're getting two sources of bass below and above the crossover point. Regardless, it's two bass sources at most.
c. Unless there's a way to make the speakers and the subwoofers work together in the 40-200Hz range (4 sources) to linearise the bass response over a wide sweet spot like in Dirac ART, I don't think this particular reason is an argument for adding two subs.
Exactly!!
I have the KH310, and a sub is needed for clean bass.
During work hours I use KH310 full range (2.0ch) and play background music not too loud. After work hours I crank it up a little, the low bass sounds boxy at times.
I switch over to 2.1ch and the boxiness goes away. Crank up even more, nice extended bass, no boxiness.
I do have my own in-room measurements that show KH310 distortion <80Hz climbs fast, and correlates with what I hear. Even Neumann data & diagram show it. I also have my in-room 2.1ch measurement showing low bass distortion far lower compared to 2.0ch.
Subwoofer is highly recommended.
这看起来像是真的,但事实并非如此。研究测量结果。KH150在40赫兹时不需要任何帮助。KH 750没有添加KH 150没有添加的40赫兹以上的内容。我有,也听过。但更重要的是,这是ASR——在科学中.....研究测量结果。
I think the larger speakers just raise the sound pressure level of the low frequency distortion。
Exactly!!
我有KH310,干净的低音需要一个sub。
在工作时间,我使用KH310全频(2.0声道)播放背景音乐,声音不要太大。下班后,我把音量调大一点,低音听起来有些方方正正。
我切换到2.1声道,这种四四方方的感觉消失了。加大音量,很好的扩展低音,没有方块感。
我确实有自己的室内测量,显示KH310失真< 80Hz攀升很快,与我听到的相关。甚至诺依曼的数据和图表也显示了这一点。
强烈推荐低音炮。
I agree with you, man.
I listened both in a well treated room side by side. unfortunately more mid clarity on 310 and more 3d imaging on 150.
Fully agree. I own the KH310. I auditioned the KH150 before buying KH310.
KH150 imaging beats KH310 for sure.
But KH310 midrange is truly exceptional.
I traded imaging for midrange :)
If one has a KH750, one does not need to have DSP monitors in order to use the MA1.1
The OP has a listening distance at 1 to 1.5 meters. So midfield or farfield would not be an issue.
The distortion level of the KH150 is so low that it is not an issue with nearfield use.
After reading 117 pages stil with doubts about what to get .
I ve got the Neumann 120a version with the 750 sub + Ma1 and I’m very happy with this system , however wanna go one or two steps forward in sound quality. My studio is well threated acousticly and it’s about 12 meters square .
I’m looking to hear more 3d sound where I can hear where to place the instruments, more mids clarity , more reverb and compression clear .
My final 2 speakers are :
Kh 150
310
Seen some folks that have both , which should i choose ?
The answer to this is almost surely in room treatment and speakers/seating layout. KH120 is a fine speaker, I doubt it is the reason for a lacking soundstage.
Kh 150
310
My serious thoughts about it after own experiences to realy get a step forward (when you want to spend some work and time in it):
- Sell the 750s
- Let build 4 or 8 Custom DIY Subs
- Build an Array (Double Bass Array / Pseudo DBA)
- and set or let set everything up via miniDSP or similiar
I had the 750s / MA1 from the beginning and my 60 L Subs are so much better than the 750. More punch & Lowend and i have now 4x for the price of ~ 2x KH750.
Just think about it. Youve less big Cables because you dont need XLR to the subs.
There are also very good pre-made Kits you can buy
(fm-audio.eu for example) already with Scan Speak Drivers and they can also measure and set them up for you.
I also think about to sell maybe the 150s in the next years because they dont have enough SPL. But its hard to find better active speakers with the same acouracy for that price.
Just as idea. With DIY you can get a custom solution wich sounds better when you do it right. And you ve an custom build wich is also a nicer feeling when you plan your own speaker setup and dont just buy off the shelf
- Sell the 750s
想想吧。你有更少的大电缆,因为你不需要XLR的潜艇。
你也可以买到非常好的预制套件
(例如fm-audio.eu)已经安装了扫描扬声器驱动程序,他们还可以为您进行测量和设置。
我也考虑在未来几年出售150,因为他们没有足够的SPL。但是很难找到更好的有源扬声器,同样的精度,同样的价格。
正如想法一样。通过DIY,你可以得到一个定制的解决方案,如果你做对了,听起来会更好。当你计划自己的扬声器设置时,你有一个定制的构建,这也是一个更好的感觉,而不是购买现成的
What subs did you use?
It is possible that the phase linearity of the newer Neumann’s can add to perceived clarity. There is a lot of early science conducted by Dr Toole, and the main conclusion has always been “all things equal, frequency response and dispersion matter more.” However, it is my personal sighted bias that speakers that seem to resonate well with me in terms of the subjective comments described have phase linearity.
And attached white paper from Meyer Sound looking at a Genelec.
较新的Neumann的相位线性可能会增加感知的清晰度。Toole博士进行了许多早期科学研究,主要结论一直是“在所有条件相同的情况下,频率响应和色散更重要。”然而,这是我个人的偏见,似乎与我产生共鸣的发言者在主观评论描述方面具有相位线性。
[URL unfull = " true "]https://audio xpress . com/article/zero-phase-in-studio-monitors[/URL]
并附上Meyer Sound查看Genelec的白皮书。
Phase linear is the highest level of monitoring, right?
My room is very nice now as i did a lot of treatment last year and i really like this kh120 but wanna ear more in the music i do/ produce .
Im trying to figure out if the 120 v2 manny people reply, are a really step up from what i have or if i have to spend a lot more for the 310 ones.
Meanwille a 310 v2 is gonna land late this year or next, who knows.
Im happy with the 120, they translate very well to other systems and im used to them, thats why my search is between Neumann models.
Or, i can keep the system i have now and in the future invest in some PMC or something in that league.
It makes no difference in sound quality
Not so sure about this. If the sub plays all content below 80 Hz and the sats play only above 80 Hz the reduction of excursion of the sats woofer reduces IMD in the complete frequency range of the woofer.
- Sell the 750s
Hmm , thanks but i dont need that much of spl power , thats not what im looking for
Manny thanks for your reply .
If i can suggest you sub drivers for diy, SB acoustics and Faital Pro makes great subwoofers for a reasonable price. A SB34NRX75-6 in a 80L sealed cabinet easely goes to 30Hz flat without dsp (in open air) and can get you an F6 (what matters for sealed subs) of 30Hz like that at 102dB (with one sub). With dsp you can even go lower, but it wil be limited in sound level (but 102dB at 30Hz is louder than you want, and room gain will drive that a bit up, even with dsp and room correction. That is a very easy build, and you can build it in the physical form like you wish, only keep 80L free space inside and fill it with damping material (whool, dacron (but loosend up) or similar material). Bracing the panels is necesairy, and the space that takes needs to be added to the 80L inside (so in reality it will be 90L or more when brace well).
The Faital Pro 12FE330-8 (or other variations of it) can do the same, but louder and in a bigger box (and not sealed, but ported). I do have a raw design somewhere (that was never build) of about 120L ported tuned to 30Hz.
And off course you also got the brute force Dayton subwoofers, the RS, RSS and UM series. They are not subtile, but go low and loud for it's size. I would not use them in studio's if i could (the SB and Faital are more refined), but for less critical setups, it's hard to beat on price/quality.
I myself use Scanspeak 26W8534G00 drivers in a 77L sealed cabinet and they are great, but not like the SB or the Faitals are when pushed. I did not know about those drivers when i bought the Scanspeaks (they were not in the market yet), but they do the job for me (i don't play very loud in my house) and are very refined and detailed for subwoofers and in an older iteration of my subwoofers, they were tuned to 23Hz in a 150L ported cabinet. That is too low for me (who is not into ht) and to big (cabinetwise) for my house at the time i build my actual subs (6 years ago) and recycled the drivers from that old one (build 11 years ago). That system is more than enough for my living room (8x3.8s2.8m)
I do plan a build with that Faital altough. I'm still in the planning phase, but it will be a multiway system with dsp, and the faital is candidate 1 at the moment to do the bass duty's. It got all the merits that i want for this project (altough i'm still looking arround). I did use it before in a 2 way system for someone with a BMS 4550 compression driver in a Yuchi style horn and dsp crossover at 1.2kHz. There it was in a MLTL cabinet tuned to 30Hz. I could have tuned it lower with that driver, but then the cabinet became to big for the client ...
But if you build a diy sub, you will need a dedicated dsp like a MIniDSP Flex (what i use) to tune it with your speakers. The Neumann subs have the advantag that they are in the same ecosystem of the monitors you have and work easier toghetter. But it's true that making better subs is not that difficult when you can program a dsp.
I am not sure what the auto translate does for you. There is debate on how audible phase accuracy is. No one ever says it’s worse. Many say that it is only audible in very specific test tones when assessing speakers in mono. Some say that when you have multiple channels, whether arrays for pro audio use or multichannel for home use, it matters a lot.
Just like high SINAD is not expensive anymore, if you are going for active studio monitors, you can get phase linear speakers at reasonable prices.
