Yes.
@MatrixAudio the product looks interesting and I have a few questions:
Thank you for your reply! If there is no companion app how to control playback for Tidal?The MA player Lite cannot manage music in local storage devices, including USB storage, NAS, SD cards. So the mini-i 3 is no need a companion app.
Install Tidal app.Thank you for your reply! If there is no companion app how to control playback for Tidal?
core
Ok, now I'm confused. How does Tidal app play on your device? Via airplay? If so how can it support MQA?Install Tidal app.
Ok that’s different from Element which supports direct stream from tidal. Roon is too expensive for my need ;-)If you want your bit perfect music from tidal, you should be using roon with the matrix audio device.
Correct.If you want your bit perfect music from tidal, you should be using roon with the matrix audio device.
That's the difference between mini-i 3 and element series.Ok, now I'm confused. How does Tidal app play on your device? Via airplay? If so how can it support MQA?
Thanks! A very good choice for Roon users.Correct.
Hi @MatrixAudio
Somehow still don't know the answer to my question, which is: Can Mini-i Pro fully render/decode MQA via ETHERNET and NOT using Roon?
Yes.
Correct.
Sorry I'm afraid I did not noticed "NOT using Roon".Hi,
@MatrixAudio I already pre-ordered the Pro version, but now I'm a bit confused about the MQA decoding...
I would like to connect the LAN cable and get full MQA decoding from Tidal Masters - without using a USB port or Roon.
And your answer below confirms this functionality:
But the information below confuses me. So I can get a full MQA decoding, but it won't be bit perfect without Roon? What is the difference between full MQA and full MQA bit perfect?
No, only via USB port.Does this have capability to render MQA via optical?
