Info. on new Matrix Audio mini-i
suttondesign
WA
I received this information from Matrix Audio, thought the forum would be interested to see a new, small streamer. I think the idea is that the unit is so small that you can just haul it around your house with you? It's got a really small antenna compared to the Element series but otherwise seems quite similar.
The new mini's page is:
https://www.matrix-digi.com/en/products/489.html
  • ELEMENT SERIES VS MINI-I PRO 3.pdf
I can't find any information about software. We know that it will be ROON ready, but roon cost extra money. Spotify maybe later in 2020. What about Tidal? Do you know. Or @MatrixAudio know?
Their other streamers support Tidal and Qobuz, so I assume these are no different.
Initial Thoughts -
  • 4.4mm Balanced Output +1
  • USB Type-C Digital Input +1
  • RCA In Analog Input +1
  • 22 ohm output impedance for 4.4mm jack -50
I'm really surprised about the headphone output impedance...why would they be OK with this?
I hope so, but there is no clear info about it
"The new Mini-i 3 and Mini-i Pro 3 use a two-color aluminum shell in silent black and space gray with a 3.3-inch LCD screen and a brand new user interface. "
We don't know what does it mean
Initial Thoughts -
22 ohms! The Matrix Element i is only 0.6 ohms. The high output impedance of the new unit is a showstopper.
This is probably the big cost reduction, no dedicated headphone amp like the more expensive series, but an off-the-shelf one which tends to have relatively high Z out.
The Element i is only a little more expensive than the Mini-i Pro 3. I would pay the difference for the discrete headphone stage.
The mini-i Pro 3 do not need the mobile app. If you would like to play Tidal on it, bluetooth and AirPlay can be the solution. By the way, over USB port is another solution.
@MatrixAudio
If the Mini-i Pro 3 is connected via Ethernet only (not USB), can it still decode MQA?? Seems so many MQA capable DACs only handle MQA via USB input exclusively. I am looking for a Network bridge/streamer/Dac (budget $1000-ish) that only needs an ethernet connection to handle Tidal/MQA and send to my integrated tube amp. Preferably with analog in/pre-amp function to gain remote control of my amp... I know, I want it all and ideally for no money...
Yes I know, but If SQ is most important TIDAL via client would be the best. Roon is OK, but create extra cost
@MatrixAudio
Roon also transfer MQA bit-perfectly to Mini-i Pro 3. :p But an extra cost needed.
@MatrixAudio
Why include the headphone amp, especially at 22 ohm impedance. I would certainly be interested in this device for a $100 or so cheaper, without the headphone amp. Seems an unnecessary cost and add on. Also can you use the USB type c port for OTG smartphone use or playback from a DAP?
Initial Thoughts -
Ouch- well that ends my considerations of this over the Element i- HPA clearly an afterthought in the mini.
Could be cool for my work shed.
Those XLR connectors would let me hook up the JBL LSR-305s I have gathering dust on a shelf.
