This is interesting…Ya a real shame they didn't include a trigger.
from the matrix audio website …..
Unfortunately that is a bit misleading. That cec capability is from the mini -> tv. Not tv to mini. I can verify if you turn the mini on, it will wake my tv. That is an odd way to do thingsThis is interesting…
oh !Unfortunately that is a bit misleading. That cec capability is from the mini -> tv. Not tv to mini. I can verify if you turn the mini on, it will wake my tv. That is an odd way to do things
This is my post from the matrix forum confirming the devices behavior
No one ever reviews hdmi interaction. Pretty important feature for me. Let's me put audio equipment in every room lol. Hopefully there isn't some hardware limitation and can be added in a future update. I think as more of these get into the wild, there may be a bigger push to correct it. Pm me when you get it. I may switch if it does everything right.oh !
so that was you on their forum !
thanks for replying to me over there !
Yeah ,
that’s messed up ….
should be both ways , at a minimum the opposite of what it actually is ….
every thing I have that is CEC works is such a manner that the TV triggers the device on/off - NOT the opposite…
I pre-ordered a Eversolo A8 … hopefully the HDMI CEC will work properly on it …
bk
I will let you know ..No one ever reviews hdmi interaction. Pretty important feature for me. Let's me put audio equipment in every room lol. Hopefully there isn't some hardware limitation and can be added in a future update. I think as more of these get into the wild, there may be a bigger push to correct it. Pm me when you get it. I may switch if it does everything right.
The 4 was important for my for the hdmi input. Other than that, you do get their latest software platform. That could mean staying in the update train a bit longer than the previous generation. If that isn't important, the 3 should be more than enough.Hmm… I’m thinking of getting one of those devices. I’d plan to use it as a Wifi Roon endpoint for headphones (Beyerdynamic DT 1990 and Hifiman Edition XS) only … so the PRO version.
Whats the main advantage of the ver 4 over 3?
- I see amirm tested slightly better SQ - not sure, but I doubt I’ll hear it.
- It plays Tidal & Spotify directly… i fear Roon is set for me (lifetime).
…both not too worrying for me or did I miss anything? So maybe go for a used ver 3 one? At least I’d prefer that plastic knob over touchscreen…
…any opinions?
The 4 is definitely an upgrade compared to the 3 but the 4 is not Roon Certified yet so if Roon is a must have for you, then you should hold your purchase until it gets certified which could take a few months because Roon is way behind their certifications schedule.Hmm… I’m thinking of getting one of those devices. I’d plan to use it as a Wifi Roon endpoint for headphones (Beyerdynamic DT 1990 and Hifiman Edition XS) only … so the PRO version.
…any opinions?
The ES9039Q2M chipset, which is the one in the mini i4, is a MQA native chipset so the chances that you can disable MQA transcoding are very little.I'm not considering functionality updates but updates to the streaming platform itself. For example tidal leaving mqa. The update to take advantage of something like that might find itself on the mini i4 but not the 3. This is all speculation but something I considered when making my purchase.
I mean tidals shift away from mqa as an example. Devices need an update to take advantage of tidals new "max" tier. Again this is just a hypothetical example.The ES9039Q2M chipset, which is the one in the mini i4, is a MQA native chipset so the chances that you can disable MQA transcoding are very little.
www.audiosciencereview.com
