I would hope so, because the more affordable Hypex Nilai DIY amps will become highly competitive with the Purifi OEM amp offerings, and it would behoove Hypex to make the most desirable options available to the DIY crowd. Hypex's current horrendous?!? (kiddin', just a little) DIY faceplate is the only thing that is holding me back from ordering one of these now (besides being out-of-stock )I imagine compatible faceplates will become available at some point.
Diy becomes expensiveVery comparable to Audiophonics fully assembled 400wpc purifi. I think I would chose laziness at that point
Most of them are half bridge. The only H-bridge coming in my mind is the NC2k.Is it possible that this matters only if the amp is single ended? .. and the supply provides +/-Vdc centered on GND.
I always thought the Hypex amps are balanced (H-bridge) but I could be wrong.
this has both higher sinad and wpc. Shipping from audiophinics is not free even if you are in France.Very comparable to Audiophonics fully assembled 400wpc purifi. I think I would chose laziness at that point
Awesome. Is there somewhere a description or discussion for this?
(I don't want to take over this thread)
Found the source of noise around 10 kHz. I had the lid open during most of the tests to allow easy switching of the gain jumper. Alas, that caused some noise pick up that was especially accentuated at 28 dB gain. I repeated the key measurements using the lid closed and there were some improvements. See the review. I also ran the pop and wide bandwidth FFT spectrum. Also included in the review.
Hypex's current horrendous?!? (kiddin', just a little) DIY faceplate is the only thing that is holding me back from ordering one of these now.
If they are they will represent incredible value for money - with a 5 year warranty! (potentially, two mono units for half the price of one Benchmark unit - with near same performance) What is missing are the dimensions of the unit. Anybody know?
Looks like a fantastic iteration.
Can you also adjust gains with the Hypex NC400?
many thanksYes. But besides the explanation of gain adjustment, it's full of voodoo. So beware:
Hypex NC400 - DIY Mods
I have recently spent a lot of time researching various possible NC400 DIY modifications, for the purpose of improving the listening experience with my amplifiers, but also having some classic DIY fun. Warnings before we continue: Attempt these mods at your own risk. These mods will almost...www.audiosciencereview.com
I like quiet about the SINAD measure , maybe the distortion is way inaudible already at much higher levels than this amp represents, but amp hiss can be audible depending on gain structure and how close your speakers are and how sensitive they are .For people dabbling in DIY active stuff that does not have the typical passive padding in treble and mid it can be even better.Btw, was asked recently about the Nilia and I do not have any personally. I only received units from Hypex to build for Amir. I did listen to it and liked how quiet it was. Not a fan of the standby switch as I power my system from an intelligent surge protector. Would I upgrade to Nilai if I had a newer Hypex Ncore or Purifi? Only if I needed the additional power...
Aside from what I already mentioned, one oddity is the gain levels. They do not match exactly to any other Hypex unit I have used.
Hope this helps!
I agree, i got the NC122MP based amp from auidiophonic (NCore first gen) and did put it next to a Purifi HPA-S400ET amp also build by audiophonics i ordered for someone, and you can't hear the difference (but in power). Both are already on a level that it does not matter anymore in reality. The Nila and the NCx amps may measure better than the old NCore amps, but it won't matter anymore in a real world setup. They are neutral and so low in distortion that they are transparent, even for people who used not to like class D like me.Btw, was asked recently about the Nilia and I do not have any personally. I only received units from Hypex to build for Amir. I did listen to it and liked how quiet it was. Not a fan of the standby switch as I power my system from an intelligent surge protector. Would I upgrade to Nilai if I had a newer Hypex Ncore or Purifi? Only if I needed the additional power...
Hope this helps!
For multi channel id suggest a better layout would be to get a case with internal height of >10cm and put the modules vertical with an individual heatsink per module. This is how nad lays out their multichannel amps.The only circumstance I see myself building a diy amp would be if I need a multichannel one and I don’t find one that fits my needs. The maths are favourable as the price of the box vs the modules gets better, and the fact that hypex diy modules are mono is also favorable, as you can chose the exact number of channels that you need.
What is not that favorable is the size and form factor. 10x10 cm for one channel without power supply the heatsink being the bottom plate? Feels that you need a football stadium to accommodate, say, 6 channels… I see that other hypex diy boards tend to be relatively big compared to their OEM and stereo boards if I am not mistaken.
This is a personal opinion that for sure does not apply to many of the customers for these modules, but I am sure I am not the only one thinking the same, just wanted to bring it up in case hypex reads it
Since when KEF is made in US?The greatest passive speakers and subs in the US
