Marc v E
Are Kef the greatest?Since when KEF is made in US?
The only circumstance I see myself building a diy amp would be if I need a multichannel one and I don’t find one that fits my needs. The maths are favourable as the price of the box vs the modules gets better, and the fact that hypex diy modules are mono is also favorable, as you can chose the exact number of channels that you need.
What is not that favorable is the size and form factor. 10x10 cm for one channel without power supply the heatsink being the bottom plate? Feels that you need a football stadium to accommodate, say, 6 channels… I see that other hypex diy boards tend to be relatively big compared to their OEM and stereo boards if I am not mistaken.
This is a personal opinion that for sure does not apply to many of the customers for these modules, but I am sure I am not the only one thinking the same, just wanted to bring it up in case hypex reads it
One of the top brands at least.Are Kef the greatest?
The first harmonic of 15 kHz is at 30 kHz. Can you hear that?Those amps go into the SINAD table with scores around 110dB and are considered TOTL/top10 amps but that's only valid at their best 1kHz point. With a 10kHz test signal you actually have a somewhat meh amp (~90dB SINAD) and at 15kHz it's a mediocre amp (~75dB SINAD). 75dB SINAD is not a top10 amp, that is a headless-panther amp in 2020.
Yes I (still) can.The first harmonic of 15 kHz is at 30 kHz. Can you hear that?
So you hear 15khz 75dB below the fundamental?Yes I (still) can.
Actually, anyone can hear that. Or more precisely anyone who can hear 15kHz.
You may wanna do a bit of research on those harmonics. You do not hear a 30kHz sound, you hear its 'coloring' effect on the 15kHz fundamental. It's so "bad" that even if you do not play a 15kHz sound but only its harmonics, you will hear only one sound: the 'missing' 15kHz. It's called the missing fundamental effect. There are also youtube demos if you still have doubts.
I am more than familiar with the missing fundamental effect. It only works if you can hear the harmonics. If you can't hear the 30 kHz, you won't hear a 15 kHz missing fundamental either.Yes I (still) can.
Again yes. Or more precisely, it is not a clear NO: may or may not be audible depending on the test signal, your ears, your equipment etc...So you hear 15khz 75dB below the fundamental?
Yes I (still) can.
Another flawed comparison between eyes and ears - they are very different.Again yes. Or more precisely, it is not a clear NO: may or may not be audible depending on the test signal, your ears, your equipment etc...
What you hear is the 15kHz at the same dB level. It's 'coloration' (btw, called timbre in musical therms) is not 75dB below, it's at the same level.
Think about it as a very "fade" coloration. A light-waves analogy might be helpful to wrap your head around it. E.g. when combining a Yellow wave with a Infrared wave you will see a red-tainted yellow (even though the infrared wave itself is 100% invisible.)
To be clear, 30 kHz would be called the 2nd harmonic. (Personally I can't hear 15 kHz much less 30 kHz.)The first harmonic of 15 kHz is at 30 kHz. Can you hear that?
Indeed. My mistake. I was thinking of it from a music point of view, where the 2nd harmonic is called the 1st overtone.To be clear, 30 kHz would be called the 2nd harmonic. (Personally I can't hear 15 kHz much less 30 kHz.)
Not sure if that is true. Think about the light analogy. Or about the 19kHz+20kHz IMD test. Most people can't hear any of those two sounds but they will hear their 1kHz IMD product.I am more than familiar with the missing fundamental effect. It only works if you can hear the harmonics. If you can't hear the 30 kHz, you won't hear a 15 kHz missing fundamental either.
would like that too.I would love to see verified, objective evidence you hear any harmonic distortion from a 15 kHz tone.
If you can't hear 15kHz you may be 'safe'. Or at least much better.To be clear, 30 kHz would be called the 2nd harmonic. (Personally I can't hear 15 kHz much less 30 kHz.)
Don't think about the light analogy - it doesn't work. As I wrote, eyes are very different from ears.Not sure if that is true. Think about the light analogy.
Sure. Because the 19 kHz + 20 Khz IMD test generates intermodulation products at frequencies such as 1 kHz. That has nothing to do with harmonic distortion.Or about the 19kHz+20kHz IMD test. Most people can't hear any of those two sounds but they will hear their 1kHz IMD product.
It is only "sure" to you. If it is inaudible, it is not coloration.The only sure thing is: the 15kHz sound will be 'colored' by its HDs.
We can say for sure. You don't hear a 30 kHz tone, and you won't hear any "coloration" of 15 kHz caused by harmonic distortion.Whether you'll be able to hear that coloration or not, noone can say (at least not for sure and not for all cases of -75dB HD)
"Probably"? So now you are just speculating?If you can't hear 15kHz you may be 'safe'. Or at least much better.
However, things that you can't hear may still produce an effect in your brain/body. E.g. a 5 Hz might kill you. A constatnt & loud 15 kHz will probably produce a sort of headache/annoyance even if you don't hear it.
What was the THD at 5 kHz again? You won't actually hear THD lower than 0.5% even on a good day at frequencies your ear is most sensitive to, not to mention 10 kHz...And guess you can still hear 10kHz, so you still get a "meh" amp. Sorry
not even sure if there is a 30kHz wave to be played by the tweeter.The only, and rather theoretical possibility are audible intermodulations in tweeter and in human ear. I am not sure if there is any serious research on this, but I believe the result would be rather negative.
BTW, 30kHz wave alone would have hard times to enter in human auditory system.
OTOH, sound and light are both waves. They combine the same way. And acoustic research/phenomena (e.g. timbre, missing fundamental) point out that ears & eyes work similarly. At least in some respects.Don't think about the light analogy - it doesn't work. As I wrote, eyes are very different from ears.
Yes IMD & HD are not the same (not 100% diff either). Anyway, it was just an example of inaudible sounds producing audible effects.Sure. Because the 19 kHz + 20 Khz IMD test generates intermodulation products at frequencies such as 1 kHz. That has nothing to do with harmonic distortion.
potato, potato...It is only "sure" to you. If it is inaudible, it is not coloration.
Sorry, won't take anyone's word/assumption here. Neither will take "common sense logic" (and yours is actually pretty good). I'd like to see some hard proof/study. But that's just me...We can say for sure. You don't hear a 30 kHz tone, and you won't hear any "coloration" of 15 kHz caused by harmonic distortion.
