As noted previously, the Amazon Prime Day sale ad I purchased from did not make it clear that the power supply was not included.Thanks for the like. Do you have any suggestions for our Amazon ads?
It depends on the subwoofer - some high level inputs work with bridged amps and others don't. You should check the manual, or ask the manufacturer if the manual doesn't say.I understand you can’t use high level subwoofer inputs from the speaker outs of this chip amp (and tbf others like it) because it operates in bridged mode. Do I have that right?
In my experience, a proper subwoofer integration requires a DSP unit. You need high-pass for mains and low-pass for subs and also you most likely need delay.Thanks. I have three subwoofers that accept high level input. None of the manuals say. Some of the makers aren’t in business anymore. So to be safe, I have to assume it won't work. That’s why I’m asking about the SW out.
This is a review and detailed measurements of the AIYIMA A70 stereo class D amplifier. It was sent to me by the company and costs US $190 with 48v @ 5 amp supply. As tested with 48v 10amp GaN supply, it costs US $220.
As you see, the A70 comes in vertical desktop configuration. Controls are easy: push the button for power up and again to cycle between XLR and RCA inputs. Hold it for a few seconds and it goes into standby. Back panel shows nice inclusion of balanced XLR inputs:
Yes, that 10 amp brick is the mother of all external power supplies!At 480 watts, any heat dissipation would be challenging given the sealed box. Use of GaN transistors seems to have enabled high efficiency as it hardly warmed up during the testing. The amp's heat source is on the bottom. I wish the feet were taller to allow better convection cooling. Fortunately that area didn't get too hot in testing.
Nice to see trigger input to allow one button power up of the audio chain from the source. We also have a sub output wit variable filter output (yes, it is controlled by the volume setting).
Diagonal speaker terminals help some to fit beefier speaker wire termination.
There is a switch to add 3 dB of gain to RCA input. I didn't realize this until after testing. It is a smart move as the gain otherwise may be a bit low for some people.
The A70 is one of the few TI TPA3255 chip based amplification utilizing post filter feedback loop (PFFB). This should get rid of load dependency and improve linearity by dialing out the distortion from the output stage. Let's see if that is the case.
AIYIMA A70 Amplifier Measurements
Let's start with setting the volume to max using XLR input (all testing with 10 amp supply):
We see a nice boost in SINAD as predicted, landing the amplifier essentially in our "excellent" category:
RCA input has fair bit lower performance but still above average:
Note that I adjusted the volume down to 25 dB per my recent standard of testing amps (used to use 29 dB).
Noise performance is excellent:
Despite its lower gain with XLR input, you can still reach full power at 3.3 volts which is well below nominal 4 volts we see out of majority of DACs. So I am good with that.
Let's jump into frequency response as that is the other big deal:
Nice! We see a bit of frequency dependency but it is outside of our hearing range.
I set the subwoofer output frequency to the lowest and measured this:
I don't know how this is useful for anyone....
Crosstalk is extremely good:
Good performance numbers give way as you go up in higher frequencies in multitone and especially in 19+20 kHz IMD:
Let's see how much power we have:
That's a lot coming out of this little box. We are talking nearly 360 watts total. 8 ohm output is naturally lower:
Edit: as noted, performance does degrade above certain frequency:
My reactive load doesn't like these bridged amps. The issue seems to be in one channel so I left that disconnected and drove only one:
The amplifier is specified down to only 4 ohm but seemed robust enough to even handle 2 ohms, albeit with a good bit of voltage drop. Translating the above into watts we get:
For those of who want to use these amps in mono, you now have that information as well.
There is likelihood of a turn on "pop" but turn off noise is completely eliminated:
Finally, amplifier was essentially ready to go on power up:
What a journey to have watched in these "chip amps." We have gone from $30 to $40 amplifiers with horrible performance to above average in less than $100. Load dependency remained though and so many of us pointing it out, we finally have a solution to that as well. Alas, cost has increased so we are not talking about a fast food meal but one at a nice restaurant. You have to decide now if the extra performance is worth it. It is to me as an amplifier doesn't obsolete so might as well get a good one and sleep easy.
I am happy to recommend the AIYIMA A70 stereo amplifier.
See this post, it has idle power consumption snapshot:Hello! Has anyone measured how many Watts of quiescent power the A70 consumes?
audiosciencereview.com
You can add some active cooling but no way to reduce idle power.By the way, is it not possible to reduce idle power consumption and idle heating even more with some technical trick or conversion?
Thank you. So there are no electronic modifications that reduce idle consumption or are difficult to solve.See this post, it has idle power consumption snapshot:
Aiyima A70 [TPA3255 PFFB Stereo] - User Impressions | Owner's Thread
Dear FMs, [ Contents: A70 Amplifier unit, 48v 5a GAN PSU and user manual/docs. > A70 amplifier unit has brick shape and non-metallic smooth finish which prevents finger prints and dust. Ventilation holes on sides and bottom of the case should help a bit with heat transfer. > TPA3255 chip is...audiosciencereview.com
However Triggered input works well on this amplifier, you might look to use it to plan turn-off through DAC/AVR or any kind of triggered output switch.
Typically 600, 500 or 450 kHz. To know which one, check the value of the resistor that goes to pin 8 (or measure the resistance of pin 8 to ground if you already have the amp) and you can find the correlation in the datasheet. I believe you can change the frequency changing the resistor and no other modification, but I am not 100% sure (I had a tpa3251 amp with switches to do so).I would like to ask at what switching frequency the A70 operates and what is the output carrier frequency residual at the output. Does anyone have this data? Also, can the switching carrier frequency of these final stages be increased somehow? Thanks for the help, please explain.
Does anyone know the A70 specifically? and can it cause problems if, for example, it is 450 now, but I raise it to 600? Thank youTypically 600, 500 or 450 kHz. To know which one, check the value of the resistor that goes to pin 8 (or measure the resistance of pin 8 to ground if you already have the amp) and you can find the correlation in the datasheet. I believe you can change the frequency changing the resistor and no other modification, but I am not 100% sure (I had a tpa3251 amp with switches to do so).
I just got the A70 with the 48v/10A power supply and I noticed I have to turn the volume up more on my preamp compared to the Fosi ZA3 with a 48v/5A power brick. Running XLR on both, thought the bigger power supply would give me more volume, not less.I have a question with my A70. I noticed that the RCA is louder than the XLR when the gain switch is on and when it's off both output has the same audio output level which should be the XLR output should be louder than the RCA Output comparing with Fosi Audio ZA3. Is this an issue? Anyone has the same experience on their A70?
I just got the A70 with the 48v/10A power supply and I noticed I have to turn the volume up more on my preamp compared to the Fosi ZA3 with a 48v/5A power brick. Running XLR on both, thought the bigger power supply would give me more volume, not less.\
Fair enough. Definitely getting less usuable volume range with my Schiit Freya S preamp. Having to turn it up to closer to 3 o'clock with the A70 compared to noon-1o'clock with the Fosi for roughly the same lostening level. Both amps were at max level on the volume knob.You're comparing devices from two different manufacturers. The only thing a 10 amp power supply does compared to a 5 amp one is it allows more current, and therefore more maximum wattage, particularly at lower speaker impedances. The position of the volume control is not an indication of how much power is available or being delivered by the amp. Your Fosi amp either has more gain in its preamp section than the A70 or a volume control potentiometer that tracks differently. (I have an A70 with the 48V/5A supply and am very pleased with it.)
In fact, as it turned out, just the same JYH38Z is on sale now.And the fact that Ali's pictures and other JYH37Z sites show this old photo.JYH38Z is now on sale and accordingly its certificate is posted correctly.You gave a certificate for JYH38Z. On sale and in the review is a power supply unit under a different number JYH37Z. What is the difference? Is there a certificate for this?
I should start by saying that acoustically it would be extremely difficult to tell them apart. Technically this Aiyima is better.hello! dear forum members, tell me, please, which one is better to choose an amplifier for acoustics Fosi za3 or aiyima a70? I am sincerely grateful in advance for your help![]()
