After 3 years A07 and 8 opamps....the best sounding opamp for me is the phillips NE5532.
Do you mind briefly sharing which opamps you have compared the Philips NE5532 and how they sounded? TIA
The front uses a fan to cool down the temperature, and the fan starts automatically when it reaches a certain temperature.For those who have one with the 10A GAN PSU, it seems from Aiyima’s photos (here and on Aliexpress) that it’s actively cooled with a small fan and grille on the DC side. Yet in the review Amir mentions a sealed box. Has it been revised? Also, I wonder whether the fan is triggered by temperature or amperage (it varies in comparable power supplies)…?![]()
(Photo from aliexpress listing as of today)
Ok thanks - I’ll look forward to tests showing how high the threshold is in practice.The front uses a fan to cool down the temperature, and the fan starts automatically when it reaches a certain temperature.
The phillips 5532 cost 2.70 euro for one and sounds naturel and musical,the jrc 5532dd,opa 1656, BB5532 and more cheaper 5532 not so good or musical.Do you mind briefly sharing which opamps you have compared the Philips NE5532 and how they sounded? TIA
I mean, Icepower specialty is bass. Do you think you could try the A70 on some treble/midrange speakers and let us know how it sounds there?bass amount and quality was far away from what I got driving it with an Icepower 125ASX. Sealed enclosure, same input and voltage via MiniDSP SHD Preamp, active lowpass at 500 Hz.
No recommendation, in addition the enclosure went very hot. Never experienced this with another Class-D amplifier.
Honestly, this amp is disappointing. I wanted to drive an 8 Ohm SB Acoustics 20 cm Bass, but the bass amount and quality was far away from what I got driving it with an Icepower 125ASX. Sealed enclosure, same input and voltage via MiniDSP SHD Preamp, active lowpass at 500 Hz.
May I ask if you have a subwoofer connected?Honestly, this amp is disappointing. I wanted to drive an 8 Ohm SB Acoustics 20 cm Bass, but the bass amount and quality was far away from what I got driving it with an Icepower 125ASX. Sealed enclosure, same input and voltage via MiniDSP SHD Preamp, active lowpass at 500 Hz.
Power cables are standard, sustained full-power operation will not be a problem, do not recommend replacing. Improve the sound quality of this can replace some coupling capacitors and op-amps. SINAD this in the current known circuit and device conditions, basically has been to the limit of the value, there is no room to improve the RCA will be weaker than the performance of the XLR, because the XLR is a differential signal, differential signal noise suppression is higher than the single-ended signal of the RCA itself, while the RCA is a single-ended signal, the noise suppression effect will be a little worse, and after the op-amp to do single-ended to differential, after each level of op-amp will produce corresponding noise and noise suppression. RCA is a single-ended signal, the noise suppression effect itself will be poorer, and after the op-amp to do single-ended to differential, after each level of op-amp, it will produce the corresponding noise and distortion.Hello! I bought an A70 the other day, with the factory 48/5A power supply. I like it so far. I am planning to replace the OPAs with 1656, based on the recommendations of a local hi-fi developer. Has anyone tried it? As I looked at the data, Amirm's measurements, I don't understand why the rca Sinad is so much weaker than the XLR. Also, I reduce the peak performance a little. As I was examining the power supply in my hands, it occurred to me: could the output power cable on the secondary side be too thin? And does it lose some performance because of this? I would like to replace it with a thicker one, but if I understand correctly, the 48V/5A Gan power supply cannot be disassembled without damage? (if it breaks, trash?). I also thought of shortening the output wire to 1/3 the length and putting a new DC plug on it. Nonsense? By the way, what hardware modifications are there that improved the sound quality, SINAD, etc.? Thank you, welcome Zoli, Hungary
Do your two amps have the same gain? Aiyima XLR input is only 19dbOf course not. This is a classic three-way design, driven by two amps thanks to its passive mid/high crossover, picture attached
@JonL: Hypex Ncore delivers a much more defined bass than the 125 ASX, so I wouldn't point out the bass as a particular strength of the Icepower modules. They are clearly no high end, but very good for solid and inexpensive applications. Therefore it was a surprise for me to see how much the Aiyima lags behind, I didn't expected that.
Thanks for the reply. I only thought about it because if the power supply was built in, the approx. Instead of a 0.2 ohm supply line, there would be a significantly lower resistance connection. Another question: does this GAN power supply accept an extra buffer capacitor on its output, for example 4700 uF/63V? Also, doesn't the amplifier itself use some trick so that if I turn on the switch, it starts immediately, without pressing a button? Then the sound system could be started with a switch, I wouldn't have to press the volume button.Power cables are standard, sustained full-power operation will not be a problem, do not recommend replacing. Improve the sound quality of this can replace some coupling capacitors and op-amps. SINAD this in the current known circuit and device conditions, basically has been to the limit of the value, there is no room to improve the RCA will be weaker than the performance of the XLR, because the XLR is a differential signal, differential signal noise suppression is higher than the single-ended signal of the RCA itself, while the RCA is a single-ended signal, the noise suppression effect will be a little worse, and after the op-amp to do single-ended to differential, after each level of op-amp will produce corresponding noise and noise suppression. RCA is a single-ended signal, the noise suppression effect itself will be poorer, and after the op-amp to do single-ended to differential, after each level of op-amp, it will produce the corresponding noise and distortion.
Check the phasing of the acoustics again.Perhaps this is the reason.Of course not. This is a classic three-way design, driven by two amps thanks to its passive mid/high crossover, picture attached
That‘s to bad to hear!Honestly, this amp is disappointing. I wanted to drive an 8 Ohm SB Acoustics 20 cm Bass, but the bass amount and quality was far away from what I got driving it with an Icepower 125ASX. Sealed enclosure, same input and voltage via MiniDSP SHD Preamp, active lowpass at 500 Hz.
Does anyone have anything to say about this? Also, I need a recommended modding list, what would you change? So far: opa1656, some bipolar electrolytic capacitors are my idea, along the lines of the Aiyima A07. Give me a tip, please.Thanks for the reply. I only thought about it because if the power supply was built in, the approx. Instead of a 0.2 ohm supply line, there would be a significantly lower resistance connection. Another question: does this GAN power supply accept an extra buffer capacitor on its output, for example 4700 uF/63V? Also, doesn't the amplifier itself use some trick so that if I turn on the switch, it starts immediately, without pressing a button? Then the sound system could be started with a switch, I wouldn't have to press the volume button.
Third question: Is the a70's bandwidth guaranteed to be straight from 20Hz to 20kHz? So doesn't the bass drop off sharply around 30-35 Hz? Has anyone replaced the coupling capacitor?
And other question: all my speakers are 4 ohms. Is it possible to push the upper frequency limit on the pffb circuit a little with a simple change so that the high pass does not drop up to 20 kHz? If so, and it is not a serious professional secret, which component is responsible for this and what is the recommended intervention? Thanks to whoever helps me with these questions. Have a nice day!
Maybe you are right, at least this what I noticed when testing these small class D amps.Perhaps we should accept that a profound, defined and beefy bass response need some effort from the amplifier too. It's a reason that a lot of pros and audiophiles still swear on some bulky and really heavy class AB-Designs to drive the lowest octave.
And once you experienced an amp which dictates the rhythm based on the bass, you don't want other solutions.
Old AB International amplifiers worked this way and were unprecedented pushing bass and pace even out of small bookshelf speakers...
If you want overwhelming bass quality via class D, you have to spend too, e.g. for the Hypex Ncore 400. There's no free lunch.
It’s probably due to headroom. The measurements show that class D typically has no headroom beyond its max power where’s class A/B allow peaks for small amounts of time beyond rated power.Maybe you are right, at least this what I noticed when testing these small class D amps.
And my hope was to get rid of the rather bulky, heavy and inefficient class AB systems.
But when this is really the case, do all these measurements like SINAD, load (in) dependency, power output per channel do have any real world consequences?
Because when just going with the specs and measurements it should be possible to drive for example my seas drivers(even with the topping PA5). But in reality it’s just not the case.
Actually Hypex and Icepower were the brands I was familiar with but I didn’t want to use them because they are way more expansive and I wanted to give some new players to the market a chance. But in the end… yeah no free lunch
Did someone else here noticed a similar behavior? That the real world output of small class D systems (especially TPA based systems) fall behind their Class AB counterparts? And why is this so?
That’s true according to the measurements, on the other hand hypex and icepower seem be able to do it regardless this fact.It’s probably due to headroom. The measurements show that class D typically has no headroom beyond its max power where’s class A/B allow peaks for small amounts of time beyond rated power.
