Audionaut
If the housing gets very hot, the aluminum block that connects the TPA3255 to the housing does not need to be any larger, as it then performs its task perfectly as a heat exchanger.A5 after 2h was on 71C
The actual housing is then too small for heat dissipation and you have to resort to additional means.
Either activated with a fan or passive with a heat sink.
As I don't like active cooling in hi-fi devices, I opted for a massive heat sink for the O-Noorus D1, which is also used in power amplifiers.
There are also cheaper solutions on AE, for example.
