AIYIMA A80 Stereo Amplifier & DAC Review
Rate this amplifier and DAC:
    Votes: 8 2.8%
    Votes: 37 13.1%
    Votes: 154 54.6%
    Votes: 83 29.4%
This is a review and detailed measurements of the AIYIMA A80 stereo amplifier and DAC. It was sent to me by the company and costs US $199.
As you can see, the A80 sports a nice sized graphical display showing one of the prettiest "VU" meters I have seen. It works well too by auto-ranging depending on how loud you play! I was pleasantly surprised to see a proper DAC integrated in it in the form of ESS ESS9038Q2M. You can see its feature set exposed in the back:
AIYIMA A80 Stereo DAC and Amplifier USB Toslink Coax back panel trigger Review.jpg
We have the usual DAC connections such as USB-0C, Toslink and Coax.
I am always pleased to see balanced inputs and we have that in the form of TRS. You can get simple adapter or cables from this to XLR.
Power supply as usual for this class is external. I tested with the 48 volt/5 amp GaN unit as supplied by the company.
We even have trigger input although with the included DAC, you won't need it.
Speaker terminals are just large enough to let me use my oversized locking banana plugs.
A remote is provided which is very nice.
Company has really nailed the functionality here. Let's see if it has good performance to go with it.
If you are not familiar with amplifier measurements, please watch my tutorial on it:
[And subscribe to the channel :) ]
AIYIMA A80 Stereo Amplifier Measurements
Let's start with analog input using balanced and see how it does at 5 watts:
This is excellent performance with distortion products below -100 dB. It is the general noise level that keeps SINAD below that. SINAD of nearly 90 dB places the A80 well above average for all amplifiers tested to date:
Digital USB input shows that the amp is the limiting factor with the DAC providing transparency:
There is a tiny bit of rise in noise floor in low frequencies but otherwise, we have the same performance.
RCA input costs some penalty especially in channel 1:
I like to see 16 bits of dynamic range and we come short a bit, literally:
At max power though, this improves beyond what most people need:
Amplifier sports PFFB design which should largely do away with load dependency but some remains:
AIYIMA A80 Stereo DAC and Amplifier balanced Frequency Response Measurements.png
If the ringing was not there at 4 ohm, perhaps the 8 ohm rise would be more negligible.
Crosstalk is surprisingly good:
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input channel separation Measurements.png
Both multitone and 19+20 kHz intermodulation distortion tests show the typical natural rise of distortion with frequency:
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input Multitone Measurements.png
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input 19 20 kHz intermodulation distortion Me...png
There is healthy amount of power here:
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input Power into 4 ohm Measurements.png
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input Power into 8 ohm Measurements.png
For apples vs apples power measurements, I test at 1% THD but the A80 would shutdown before reaching that level of distortion (atypical of TPA designs). So I opted for 0.4%:
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input Max and Peak Power into 4 ohm Measureme...png
My 40 Hz low frequency power rating likewise required messing with the THD percentage:
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input Power into 4 ohm 40 Hz Measurements.png
So a bit of loss there.
I had to reduce the percentage even lower to get a power sweep from 20 to 20 kHz:
AIYIMA A80 Stereo DAC and Amplifier balanced TRS input FTC Power into 4 ohm Measurements.png
This demonstrates the difficulty of a priori deciding to measure power at 1% THD. This amplifier would have produced zero power with that rating!
I forgot to run the power vs frequency sweeps. Will see if I can run them later and add to the review.
The aggressive protection circuit would have made it a pain to run the reactive load tests so I didn't.
There is a mild power on pop:
AIYIMA A80 Stereo DAC and Amplifier balanced Power on off noise pop Measurements.png
The amp was stable on power up, requiring no warm up:
Post running the FTC stress test, I took an infrared image of the case which had warmed up fair bit:
Distribution of heat is very good.
Usually, any digital input in this class of amplifier is a "checklist item." In the A80, we have a serious DAC that provides a transparent path to the amplifier. The design is excellent given the wide high res display which can show levels, spectrum, etc. Company has clearly been listening to our feedback. Performance overall ranks from very good to excellent for the class. The only miss is less than perfect frequency response. For those of us older, we can't hear that high up anyway but for others, the response with a simple resistive load should be flatter.
I am going to recommend the AIYIMA A80. I believe it is going on sale next week.
Reserved for @AdamG to kindly post the specs.
Manufacturer Specifications:
Link to additional details and product information:
That does stand out compared to other TPA3255 based amps using PFFB. Nice to see the results on this though, thanks.
Some pics;
The preamplifier stage features DIP8-mounted OPA1656 and NE5532's.
These are from the other discussion thread posted by @ICIETDIYEUR, DAC appears to be a ES9038Q2M;
JSmith
I would like to see the test of the sample form the market of these almost perfect 200$ amps.
Why? Amir has measured a number of Aiyima amps and others have also tested purchased ones showing the same/similar measurements.
If you're getting at that this is a "golden sample", if it was, Aiyima would get caught out easily and lose their business reputation.
So on that basis I think your assertion is misplaced.
JSmith
'We even have trigger input although with the included DAC, you won't need it.'
Select WiiM streamers can add the options of WiFi input and Parametric EQ to the Aiyima A80 while powering it up or down with the included 12 volt trigger input.
Select WiiM streamers can add the options of wireless input and Parametric EQ to the Aiyima A80 while powering it up or down with the included 12 volt trigger input.
There is a note in their graphics indicating it doesn't work with WiiM! Not sure why.
My Fosi ZD3 and WiiM Ultra, when I had them, matched Amir’s measurements. Same with my Topping D90. That said, my ZD3 is glitchy with my Sony TV and AppleTV when it comes to accidentally powering on for no reason, and my WiiM Ultra had more noise in the right channel compared to the left which was audible.
In the case of the goal of a small HDMI DAC, I ended up going to the Bluesound Node Icon at $1000. It works perfectly. A lot of times the extra cost savings for these products comes in the realm of software. We have seen countless complaints (not this one) about mismatched fonts, DACs used as standalone preamps which randomly go to maximum volume, etc.
Getting an E1DA Cosmos ADC is one way measurements have been democratized. We, in the community, can provide the peer review with commercially purchased products. Looking at the E1DA Cosmos ADC, or any IC datasheet, there are clearly accepted tolerances and I don’t doubt that manufacturer supplied gear will be the best among the accepted tolerances, but at least in my real world testing, I haven’t found anything amiss with my SINAD evaluation. The D90 does invert its XLR from convention pin 2 hot.
Of all of those, I only have the ZD3 left because it is a decent tone generator for testing other electronics.
Edit: Thinking about it, my Topping D50s never measure as well as Amir’s when using desktop/laptops for USB power. It is sensitive to USB adapter, so Amir’s formal test lab definitely is the best case scenario. There are also issues of the APx555’s superb input impedance giving higher SINAD scores than what is achievable with many actual consumer products that have been reported.
JSmith
Why?
We should encourage that, the more independent tests, the better.
More so if tested at different conditions too, an example is yesterday's Icon review who looses some 30dB digital performance just by engaging a -0.5dB filter down low.
It's not only about golden samples, is different conditions, tests, etc
At the DUT, really nice combined performance, lot's of set-ups would be more that OK measuring like that as a chain despite their nicer measuring individual components.
Thank Amir!
That is unfortunate. Thank you for the update !
I wonder if they mean it doesn’t work with WiiM in USB DAC mode, but coax/optical would be fine? At least I hope that’d be the case, otherwise there’s likely some other common incompatibility others will run into. Unfortunate for sure, but nice to see the manufacturer being open and upfront about it!
Maybe you misread the chain of posts my friend, all good... I agree with you on the above and referred to same as a reason not to be concerned about a "golden sample". :)
The chap I replied to wasn't asking for others to verify the results posted here from my understanding, he was saying Amir should have tested a purchased "market" sample instead of one from Aiyima.
JSmith
JSmith
Oh, the specifics of an external sample?
No, didn't get that.
If we want to max "correctness" though, practice is to take several samples from different batches, etc, the works, so we can see sample to sample variation too.
I suppose we should be glad with what we already have though.
As Amir mentioned, perhaps the Aiyima A80 is slated to go on sale next week.....
Currently, the price of the Aiyima A80 with the 48 volt power supply is $229.99.
Agreed
In the absence of that alternative, I am very glad with what we have.
Reactions: EJ3
