AIYIMA A80 Stereo Amplifier & DAC Review
Rate this amplifier and DAC:
    Votes: 8 2.9%
    Votes: 37 13.2%
    Votes: 154 55.0%
    Votes: 81 28.9%
Hy, I have the a80 on my PC usb connected. Everything is ok ish, before I had the A07 Pro from Aiyima and a separate dac . The sound with previous sistem was better than this A80. It's not bad , but not as good as before . Someone on the forums said to change some caps , any idea which ones . Also I put Muses02 Opamp, the sound got better but not by much .
A80 is a excelent solution for PC use , but the sound could be a bit better .
Would try to upgrade if someone knows what to change ...?
With A80 I see lower gain (aka amplification). That might affect your sound perception. I had the same issue with A07 (29dB gain) and Topping PA5 II+ (19 or 21 dB gain). A07 just sounds better to me, while PA5 much cleaner/noiseless.
I had the A07 pro , but no subwoofer output so i used a high low auto filter, it worked well . I used the A07 pro with A08 DAC from aiyima. I said i should change at this all in one A80 , but the sound is not the same , i think is a little worse on this A80 , not much but i think the first sistem sounded better . But i have to admit its an all in one desktop PC solution , so its more compact , less wires and looks really cool . All in all the A80 is a good amplifier , not so refined in high volumes, but good amp nonetheless .
I have the Kanto YUP 6 aka Kanto passive 5.25 and a presonus sub 8 .
The sistem is more than enough for pc use scenario . And i also changed the opamp to MUSES 02 on the A 80 .
But again i liked the sound from A08 DAC With A07 standard opamp pro better , the only downside was i had to use that audo low high adapter and some more cables from DAC to amp .
Have had the A80 for a few weeks now and overall they are quite enjoyable playing over my Kef Q100's.
The display's input selection information is pretty much useless though in a livingroon situation. Same goes for the volume indication. Why they did not opt for numerical values is beyond me.
One niggle I've had is with the optical inputs; anything playing back over that ( tv audio ) in the first few minutes - be it xbox game of netflix etc - there are stutters and brief moments of no sound at all. Thinking of returning as none of my other little class D's from SMSL etc show this behaviour..
Do I need to install any drivers before I can use the usb connection to my cell phone or tablet streaming Spotify/apple music?
I bought this amp and returned it, as I found that there was no gain at all. I had to turn the volume at least 80% to get a good loudness, at 50% it was non existent I tried both usb and Bluetooth connection same volume levels.
RCA and BT input volume is on par with other amps I have - the Optical SP/DIF input though I have to crank up quite a bit to achieve same level.
So it's normal that this amp needs to be cranked to 70-80% to get comfortable levels, but then again I have a fosi audio bt20a and its exactly the same, so maybe these class d amps work like this?
That sounds excessive =/ No here to get around 75db it goes from the blue into the purple quite a bit on sp/dif - rca is maybe 25%
See thats the annoying thing about having dots for volume indication =_=
What speakers are you using with A80?
Kef Q100. Not terribly efficient speakers. Sounds like you definately had a dud A80.
Well me too w regards to sp/dif maybe ^^
I have missions qx4 mkII which has got a sensitivity of 88 so it shouldn't have been to hard to drive them. Maybe I did get a sud unit. Might order again from Amazon.
oh those look nice. I've not heard Missions since the 90's ( 753 ) They disappeared from view from the few hifi stores that were left here at the time but looks like they made a good comeback. I'd give it a chance w regards to the Aiyima - at worst its a few days wait for money back w Amazon at least
Good idea but I'm leaving the UK to go abroad which is where my second setup is so will either re-order the A80 again or just carry on using my 7 year old Cambridge Audio CXA80.
Safe journey o/
I think for a time there there was more demand than supply for these things - maybe they rushed them out a little too hastily. I have to say other than the sp/dif issue and the uselessly small input selection and volume on the display I have thoroughly enjoyed my music using this little amp.
At the speed this company operates it wouldn't surprise me if they put another 'banger' out by Fall so either way - whether you order another A80 or the A100 hits the shelves - I think you will like what you end up with
Just returned mine over the issues with sp/dif and think I can stand to wait for a Mk2 of this amp which maybe also sees a redesign of the display so input is more visible from a distance in living room conditions, and hopefully volume information is indicated with also clearly visible numerals instead of small dashes.
I will miss it much meanwhile though
I don't think PEQ makes sense with a device like this, but analog subwoofer-HPF is a problem that has been well solved for over 40 years, as are external active crossovers for little money.
Could you give an example of a model?
Thomann the t.racks DSP 4x4 Mini or the symmetrical t.racks DSP 4x4 Mini Pro for €/$119 or €/$159.
UK-based ZinAMP offers high-quality active analog crossovers, individually configurable and scalable. Available as DIY boards or pre-assembled. DIY circuit board set 3-way stereo from approx. €/$ 45.
Hi everyone,
After reading the good review from @amirm, I'm considering getting the Aiyima A80 for my second residence, where I don’t need a high-end system but still want decent sound quality. The price is quite attractive, and I'd rather save money on the amp to invest in a good pair of speakers—I'm thinking of the Monitor Audio Silver 100 (7G).
Most of my listening would be from a NAS over the network, so I'll likely use the A80's built-in DAC.
A couple of questions:
  1. Do you think the A80 + Silver 100 (7G) is a good match?
  2. Would it be worth upgrading the Aiyima’s power supply for better performance?
Any advice would be greatly appreciated!
Thanks!
I'll be comparing the stock 48v 5a GaN, with the 48v 10a, when I receive my A80.
