NAD C 3050 Integrated Amplifier Review
Rate this amplifier:
    Votes: 19 6.6%
    Votes: 139 48.4%
    Votes: 122 42.5%
    Votes: 7 2.4%
This is a review and detailed measurements of the NAD C 3050 integrated amplifier with included DAC and optional streaming module. It is on kind loan from a member and costs US $1,599.
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Review.jpg
As you can tell, the C3050 has my all time favorite feature, dual VU meters! :D They are crisp and nicer looking than many others in modern gear. They have an indication for 8 ohm but when measuring at 5 watts, it showed the wrong value in that load. It was correct for 4 ohm but then wasn't accurate at other levels. So it is really more for fun than accurate power metering. There is a switch to make it show the input signal instead of output in the back. Wish this was in the front.
Nice to see the tone control. Not so nice is lack of tone defeat. I especially disliked the rotary volume control which has a so so feel and those LED that look out of place and don't tell you the actual level. An annoying thing is the BlueOS green LED constantly blinking. I assume it is showing network activity but why would I want to see that all the time?
The top and surrounds have a vinyl wrap which looks decent from far but has a real plasticky feel which is a major departure from the vintage look they are going after. The grill on top is fairly open allowing you to see the Hypex Ucd class D amplifiers which in operation, ran quite cool. Back panel shows a mix of vintage and modern features:
NAD C3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter back panel Review.jpg
I got a kick out of those jumpers from pre-amp to power amp which was a cool feature back in 1980s. They would still be useful today to use a higher power amp. We have modern features such as HDMI ARC, S/PDIF and trigger support. There is Dirac functionality which I imagine is part of the BlueOS streaming option. Don't care for the bright colors of the speaker terminals but they are otherwise functional. I am happy that they did not put in a captive power cord to match what we used to have in early days of hi-fi.
NAD C 3050 Amplifier Measurements
Let's start by setting the gain to 25 dB and seeing how the analog input performs:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Analog In Measur...png
Not bad. That is the average noise+distortion of all amplifiers ever tested. Let's test it with Toslink digital:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink Optical ...png
This is noticeably quieter, allowing to SINAD to raise to a respectable level:
Here is the direct comparison of noise at 5 watts:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Analog In SNR Me...png
I do like to see better noise performance though. Fortunately at full power, we get there:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Analog In SNR Ma...png
Frequency response shows that analog input is digitized at lowest sampling rate:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Analog In Freque...png
I was hoping for a pure mode or something that would allow it to go in without double conversion. Then again, this allows analog input to be subject to Dirac correction.
As with noise, crosstalk is better with digital input:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Analog In Crosst...png
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink In Cross...png
Multitone test shows rather constant level of intermodulation distortion:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink In Multi...png
I would have liked better high frequency performance:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink In 19 20...png
Power is rated at 100 watts for both 4 and 8 ohms which the test unit produces and then some:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink In Power...png
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink In Max a...png
Power is however variable with frequency, with 40 Hz dropping fair bit as you see above and below:
I could not run peak power test as the protection circuit would intervene. For the same reason, I could not test reactive loads either. Our stress power test showed variability:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink In FTC P...png
I can't explain why power is lower in upper bass than lower. It may have something to do with recovery from clipping.
Frequency power sweeps show what I stated before regarding more or less constant distortion+noise:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Toslink In frequ...png
Have we seen this with UCd amps before?
Power was stable upon turning on the unit other than a glitch:
NAD C 3050 Stereophonic Amplifier stereo DAC amplifier Dirac Room EQ VU Meter Warm up Measurem...png
That glitch may be what was interfering with power measurements.
I did not test the other subsystems.
While NAD could have done a bit more on design, what is there is rather unique with inclusion of VU meters and such. I say what is there is good enough as is objective performance of the amplifier. It runs cool and is reasonably priced. So somewhat interesting but not all that it could be.
I am going to recommend the NAD C3050 amplifier.
Reserved for @AdamG to kindly post the specs.
Manufacturer Specifications:
Link to additional details and product description:
So SINAD is 81 dB as using Toslink wouldn't be fair for the chart at least.
Well, the analog input is digitized so is not the same as analog input on other amps/AVRs where I have tested them in "Pure" mode.
I wonder whose amps they are using in this unit?
With so many competent solutions available I guess it comes down to money?
@amirm reminds me of my HD-AMP1, I recall you had weird readings with it. Another Hypex…but was in the before times, you didn’t test the digital inputs.
NAD seems to use the Hypex UCD102 in this amplifier. They might use the smallest UCD unit because of its ability to drive 2 Ohm loads, which the bigger 180, 250 and 400 cannot. I can't help myself but I find the performance of this amplifier a little bit underwhelming. But I love the styling admittedly...
It's rather disappointing that NAD can't beat their own budget integrated amplifier from 20 years ago:
I know it's not an entirely apples to apples comparison, this newer amp has a fair few additional features, but none the less.
No go for me because I would get better performance setting up a non-integrated chain of DAC/pre/power amp by Fosi at roughly half the price. It is too early in the morning to be more specific w Fosi chain. Interconnects between each, ASR show, do not need to be expensive anymore…Thank you Amir for this impeccable review!
There are not that many stereo amplifiers that include a viable room-correction system, so I can understand that for people who are in the market for a traditional integrated amp this is an interesting option. Combined with the '70s esthetics (add some Wharfdale Lintons) you end up with (kind of) SotA technology and hip vintage looks. I can see the attraction.
Thanks for the test Amir.
Like many I suspect, I started out with a NAD 3020 amplifier, and have fond memories.
The recommendation seems quite generous though.
I expected better things from NAD, this is worse than an AVR, and that's saying something.
"Not terrible"
The tested version has had the MDC2 BluOS-D Streaming Module installed;
If that's the case and as Amir said the tones are not deflatable we may have some short of explanation for the bad performance.
We saw some 30dB penalty at the Bluesound thread by enabling tones alone, without any correction.
i;m gonna say this one performs all right given the intended audience
i though this was limited edition but this is the normal production 'non limited'
and so the styling is supposed to appeal to enthusiasts slash tragics
and so performance has to be at a "above average" level but it doesnt have to be spectacular and who expects that at a mere $1.4k??? NAD have their 'Masters' line do they not?
to me this like Yamaha's AS-1200 moment but I prefer the Yamaha...
Agreed. I would have considered an NAD C 3050 if the retro aesthetic was accomplished with a veneer of wood instead of plastic.
