AIYIMA A70 Mono Amplifier Review
Rate this amplifier:
    Votes: 16 7.8%
    Votes: 62 30.1%
    Votes: 106 51.5%
    Votes: 22 10.7%
It's ugly, but at least it's symmetrical in design!
As for seemingly duplicated subwoofer controls, it's because the large dial on the front controls the low-pass frequency crossover point of the speaker-level outputs on the back, whereas the small knob on the back controls the low-pass frequency crossover point of the RCA LFE output.
You know, so if you wanted a really huge active subwoofer for the deep subbass, you can attach that to the LFE, and then separately you can drive a smaller passive subwoofer from the speaker level outputs for the upper bass. Or something. I don't know, I made this last part up, I'm not actually recommending it.
-Ed
Is there a beter way to rate the amplifier with one number as the alternative to SINAD at 1kHz?
''Good'' amplifier, SINAD 94dB
''Bad'' amplifier, SINAD 89dB
Not see where the tpa3255 can play his good parts in mono mode here. In theory it could go down to 2ohms. But not testet ? At 2ohms it could be interesting as a sub amp. But no info ? Not happy with the info at the moment. From my point of view a tpa3255 in mono makes only sense at 2ohms. You know more? Cool tell me?
At 2ohms it should be in the 400W region. Not bad for a 100$ amp. And who cares about +1 db at 30k if you use it as a sub amp? Two 15inch in parallel at 400W can be bad ;). So from my point of view its a little the wrong test. Testing a sports car on the dirt track and vice versa.
This is a review and detailed measurements of the AIYIMA A70 Mono TI TPA3255 based class D amplifier. It was sent to me by the company and is on sale for US $116.
The on/off and input type selectors have good quality feel to them as do the rotary controls. Right one is volume but left one had my scratching my head. Subwoofer frequency? That is something you set once so you don't need front adjustment. Even if you did, what is one in the back that has the same name?
As is, measurements showed that neither made a difference in frequency response of the speaker output. If you however toggle a switch underneath, the front control at least becomes active, setting the high frequency roll off. I could not figure out what the back control did. Reading the instructions didn't help but my conclusion was that the switch turns the amplifier into one that drives passive subwoofer (woofer and no amp). Passive subs have fallen out of favor in US at least for more than two decades. You can get ultra low cost subs that are active. AIYIMA has seemed to gone to great lengths to implement such a functionality with dedicated front and back controls. It is quite puzzling to me. Hopefully you all didn't talk them into this! :)
Nice to see trigger input so amp can be woken up by the source having the same output. And inclusion of extra gain for RCA solves the battle of what the gain should be by default. I like the default of it being off. But some want higher gain (which brings with it more noise and potentially channel imbalance).
I forgot to take a picture of the power supply but it is GaN based, 48 volt @ 5 amp for total of 240 watts in a relatively compact package. In use neither the power supply, or the case (top or bottom) warmed up let alone get hot. Either thermal management is very good or hot stuff inside care isolated from the case.
Note that there is another AIYIMA A70 amplifier (without mono). As with that unit, the mono version here implements post-filter feedback (PFFB) so should have high level of isolation from load/speaker dependency compared to units without. We will measure this.
AIYIMA A70 Mono Measurements
Let's start with XLR input at max volume:
Distortion is at inaudible -110 dB so noise dominates SINAD at 94 dB, placing the A70 mono at the top of the "competent" group of amplifier we have tested:
RCA input is similar despite higher gain:
I am happy to see 25 dB gain here as that is what I think companies need to target unless max power is not reached with 2 volt input.
Frequency response test shows that PFFB is working, sans a bit of increased output impedance:
Given that the 4 ohm also peaks at 20 kHz, the 8 ohm peak is now 1 dB higher than mid frequencies which may be audible to some young people.
SNR is excellent and matches spec fully:
I was surprised by the increasing intermodulation distortion in low frequencies in multitone test:
It is not something I have seen in other implementations. Fortunately our hearing threshold is pretty high at lower frequencies so likely not audible. The rise in the same at higher frequencies is typical:
Let's measure available power:
Sweeping at different frequencies we see the jump in distortion at lower end of the spectrum (20 Hz):
On positive front the curves are much smoother and don't rise as much as some other implementations.
Power is nicely maintained across full audible spectrum (with a degree of error):
I went to test the amp with my Loadbox reactive load but sadly, found the load box not communicating with the PC anymore. :(
Here is the impressive warm up performance:
I didn't take a thermal image because as I noted in the intro, the amp and its supply were at room temperature more or less.
AIYIMA A70 MONO amplifier brings highly competent performance to the table with performance that beats majority of amplifiers I have tested. Yet it costs so little. Having balanced input, selectable gain for RCA and trigger are much appreciated. I am at a loss as to what the subwoofer features are about but fortunately, they are disabled using a switch. To be clear, what we/I want is to roll off the main output and have an unmodified output for sub. The sub will have its own filtering. It is the mains that needs filtering.
I am going to recommend the AIYIMA A70 Mono amplifier.
Sure, most "ready to wear" subwoofers nowadays are active. But for my HT I home brewed an infinite baffle box (2 x 15" drivers) that mounts under the floor, and tuned it with Dirac. So all I need is a reasonably powered, quiet Class D mono amp. This one falls a little short on power for my system, but otherwise seems like a reasonable compromise.
The Cambridge was knocked down due to poor performance of its DAC. If it were an amp only, it would get a "recommended" ranking as well.
You are absolutely right, 1kHz 5W SINAD can be called as almost pointless number. And its use as a sound quality comparison number confuses crowds of laymen ASR readers.
Aiyima always follows Fosi's lead—where Fosi goes, they follow. It makes me smile a bit. Since the V3, they've started cloning Fosi’s ideas and innovations, both in terms of technical solutions and implementations. Of course, competition benefits consumers, but I always get the feeling they’re like that classmate who doesn’t have ideas and peeks at the smarter student’s paper.
i kind of agree... companies respond to each others product lines if there's success ie. sales to be seen
HOWEVER I would give kudos to Aiyima for doing this 'subwoofer amp' thing too - they saw how maybe selling single units as sub amps could be useful?
Its their odd implementation of it i'm not a fan of
in the original thread the Aiyima rep. tried to explain what the front panel and rear sub output does but yeah... I mean... if you are trying to make complex products then you need to follow it up with clear usage diags or whatever on your site AND in your manuals
I dont think Aiyima wins anyone over with their implemenation of whatever they thought was going on with this unit.
It reminds me of that Douk A100 whatever that was announced here. I'm shaking my head with both these devices.
Probably, but fosi also got very much inspired by the 3e audio boards, and let's not forget that Aiyima were the ones that bring the tpa3255 to the masses and particularly to this forum with the original A07. One could argue that all these amps are descendents of it.... credit to where it is due.
Thank you all audio enthusiasts for your attention to A70 Mono! This is an explainer video about active vs passive subwoofers, click on the link to learn more.
If you have any questions, please leave a comment and let’s enjoy music together!
1KHz 5W SINAD has long been used as the single metric for ranking.
These two graphs however is a good example that the 1kHZ 5W SINAD is not always a good represention of SINAD across the spectrum.
Can the single SINAD metric be bettered?
To replace the 1KHZ SINAD with the average SINAD across 0Hz to 20KHz?
Pink panther wants pink knobs, that is how the universe is running.
I mean... there are options... on the aftermarket.
e.g.,
My feeling is this is an amp for those that like to tinker. The dual sub filters will likely be may be redundant with the subs filters, but will let folks listen to both filters, and may actually prefer say the amps to the subs.
