3e audio A7/A7 Mono Amplifier Review
Rate this amplifier:
    Votes: 3 1.0%
    Votes: 9 3.0%
    Votes: 77 26.0%
    Votes: 207 69.9%
This is a review and detailed measurements of the A7 / "A7 Mono" stereo power amplifier with balanced inputs. It was sent to me by the company. I have no idea what it costs in US. Audiophonics lists it for 379,00 €tax incl.
While the A7 may look like its competitors, it has a heft to it that I don't recall others not having. It really feels like it is filled with lead or something! A nice volume control in the middle adjusts the gain but it can also be bypassed using a switch in the back. Pushing the volume control quickly switches between XLR balanced and RCA. Two thoughtful clipping indicators are provided, making me wish it would be a standard feature on any amplifier. A minor nit: LED colors indicating which input is active is red and clipping in green. I think based on convention, the latter should be red.
Back panel shows nice set of features:
3e audio 3eaudio a7 class D stereo audio amplifier balanced back panel GaN Power supply review.jpg
Trigger input is provided as is the aforementioned combo TRS/XLR balanced inputs. Low and high gain switch is provided but I focused on low gain as that is fully compatible with current audio products outputting 2/4 volts. Yes, there is that monster GaN power supply! It can of course be purchased with other options. The input connector says max is 48 volt but per designer, the mono configuration, which is just using the left channel, can go up to 52 volts. He said I could test in stereo just the same and that is what I did. I found no issues.
FYI, I was impressed with the secure way the power supply input accepts the plug. There is a lot of current and power involved here so good to see a tight fit.
One nice feature, beside trigger, is auto-shut off in case of no input signal. I left it on by accident and was pleasantly surprised when I came back and it had gone to sleep.
3e audio A7 Amplifier Measurements
Let's start with low gain, volume control set to (volume bypass didn't make a difference), and XLR as inputs:
3e audio 3eaudio a7 class D stereo audio amplifier balanced measurements.png
Very nice. Well above average in performance with distortion below threshold of hearing:
RCA input as usual loses a bit, but not much, scoring 100 dB with again, inaudible distortion:
SNR is the limit here, which is quite good actually:
3e audio 3eaudio a7 class D stereo audio amplifier balanced SNR measurements.png
At full power, it provides transparency for practically all music produced!
The A7 uses post filter feedback (PFFB) so it is essentially load (speaker) independent:
3e audio 3eaudio a7 class D stereo audio amplifier balanced frequency response measurements.png
Crosstalk while much better than average, is a bit worse than 3e audio A5:
3e audio 3eaudio a7 class D stereo audio amplifier balanced Crosstalk measurements.png
As is typical here, above 1 kHz, distortion does climb:
3e audio 3eaudio a7 class D stereo audio amplifier balanced multitone measurements.png
3e audio 3eaudio a7 class D stereo audio amplifier balanced 19 20 khz measurements.png
This is one powerful little amplifier, easily besting its nicely mentioned specs:
3e audio 3eaudio a7 class D stereo audio amplifier balanced power 4 ohm measurements.png
3e audio 3eaudio a7 class D stereo audio amplifier balanced power 4 ohm max and peak measureme...png
3e audio 3eaudio a7 class D stereo audio amplifier balanced power 8 ohm measurements.png
Edit: forgot to include the power vs frequency sweep:
3e audio 3eaudio a7 class D stereo audio amplifier balanced power vs frequency distortion meas...png
Power is more or less sustained across the full audible band:
3e audio 3eaudio a7 class D stereo audio amplifier balanced power 4 ohm FTC full range measure...png
Its distortion goes from 0.05% to huge amount as it clips so I could not test it at 1% THD at higher frequency. So I searched for power point at just 0.05% which disadvantages this amp a bit.
My reactive loadbox still doesn't like these bridged amplifiers so I could only test the left channel (although per above, stereo and mono performance were the same):
3e audio 3eaudio a7 class D stereo audio amplifier balanced reactive voltage load measurements.png
3e audio 3eaudio a7 class D stereo audio amplifier balanced reactive load Power measurements.png
You have to keep reminding yourself that this much power is coming out of this little box, no bigger than the old CD cases!
Finally, the amplifier is rock solid on power up:
3e audio 3eaudio a7 class D stereo audio amplifier balanced warm up measurements.png
Oh, too much on my mind so I forgot to run the power up/down glitch test.
If my memory serves me right, 3e audio was the first company to bring us high performance TI TPA3255 class D amplifiers with PFFB. While they have more competition now, it is clear they intend to stay on top of this game, squeezing every bit of performance out of this architecture, while providing nice feature set. We are talking high performance, high power amplifiers that are tiny yet deliver what people need in most cases.
I am happy to recommend 3e audio A7 / A7 Mono stereo audio amplifiers.
On these large external power supply bricks, I'd like to see companies start adding a threaded outer shell. I have some gear like that. It plugs in, but the outer shell screws down a few turns to make sure the connection is firm, good and won't get accidentally pulled loose. Or I have a medical device with that type of PS. It can sense when the plug has been slightly pulled out. It will still be working fine, but will pop up a warning to indicate you need to re-seat the power supply plug.
Looks like a lot of amp in a small package.
Absolutely. Also, not adding too many cents to the BOM. Topping show this solution with the B200 for example.
idk man I worry about the color of my airbags
Fact is that many manufacturers opt orange/red led indicator as normal, I have Geshelli Labs DAC next to A7 and it has 4 same color indicators.
No complaints, at least they match :)
Is it really that big deal?
Those indicators don’t light up in normal operation and just turn up momentary on clipping.
Geez, you really want to suck the fun out of things just now when this place could use a few innocuous, light hearted comments?
The answer is no, no one really gives a shit what color the lights are.
I know you're shorthanded but might want to fix this line "This is one powerful little speaker" above the 4ohm power vs distortion test.
Do you need to provide your own power supply?
ps looked at site, seems the package for EU 379.00 gets you a 48V mains adapter altho suspect that's 220V....
