Imo it's worth trying unbalanced and getting the best SVS sub you can afford.Anyone know of a good sub with balanced ins and outs with a variable high-pass filter for under $1k with good low (sub 25hz) response at 3db? I checked out the spreadsheet but it doesn't look like there are many options. The RSL speedwoofer 12s looks like it would be perfect, except I would hate to give up balanced cables in my setup (raspberry pi running Volumio to an SMSL DO300 DAC to Kali IN-8v2 monitors). I'm also considering Kali ws-12 but it doesn't play as low as I would like. Is it worth ditching balanced to go with the RSL? Any other options I should consider? This will be solely for music playback in my living room. And no, I'm not interested in adding a pre-amp to my setup. =)
Are you needing to use the sub to high pass filter your mains? If not then the Rhythmik F12 would be a good option. If you need the HPF for the mains in the sub then there is an upgrade to the A370XLR2 amp but its only one channel so you'll need stereo subs. It's not variable but 80Hz is perfect for most applications assuming your main speakers are not too small. 80Hz would be a good hpf setting for the Kali In-8v2 monitors.Anyone know of a good sub with balanced ins and outs with a variable high-pass filter for under $1k with good low (sub 25hz) response at 3db? I checked out the spreadsheet but it doesn't look like there are many options. The RSL speedwoofer 12s looks like it would be perfect, except I would hate to give up balanced cables in my setup (raspberry pi running Volumio to an SMSL DO300 DAC to Kali IN-8v2 monitors). I'm also considering Kali ws-12 but it doesn't play as low as I would like. Is it worth ditching balanced to go with the RSL? Any other options I should consider? This will be solely for music playback in my living room. And no, I'm not interested in adding a pre-amp to my setup. =)
Dynaudio 18S might be an option although it is somewhat over budget.Anyone know of a good sub with balanced ins and outs with a variable high-pass filter for under $1k with good low (sub 25hz) response at 3db?
I saw this one and it looks like a great option, but definitely more spendy than I would like.Dynaudio 18S might be an option although it is somewhat over budget.
Understandable. But you might be out of options then.but definitely more spendy than I would like.
Looking at the subs with available CEA-2010 measurement data in the sheet, the following three have the highest calculated "bassaholic" rating within the 300€ budget:Do you guys have a recommendation for budget friendly options, say up to 300 € ?
I was thinking of buying a PreSonus Sub8BT for 199 € but it doesn't seem to have any test data in your sheet. :/
Also i have active studio monitors so i guess my sub should be active as well and i liked the idea that it has bluetooth for if friends want to connect to it.
Any contenders at this price point?
Thank you
97.6 | 100.7 | 107.5 | 112.3 | 113.1 | 114.4 | 113.6 |
For 300€, I recommend looking at the used market. Just about all subwoofers on the market are active, and you should be connecting through whatever feeds your speakers, not the subwoofer.Do you guys have a recommendation for budget friendly options, say up to 300 € ?
Thank you
90.8 | 104.9 | 108 |
104.8 | 109.1 | 113.6 |
SVS PB-1000 is my choice for value if they bring it back during one of their periodic sales. Last time they brought it back, they had it for $450.Looking at the scores and prices, it seems the best bet for under $600(amazon has it for $537) is the Monolith M10 V2. Anyone have any other recommendations under that price?
I have a fb marketplace Pb 1000 on sale for $250. I would assume that is a great deal? Only issue with buying discontinued products is finding another one so I can eventually have two.SVS PB-1000 is my choice for value if they bring it back during one of their periodic sales. Last time they brought it back, they had it for $450.
