Ralf Stocker
- Joined
- Jan 22, 2019
- Messages
- 148
- Likes
- 91
Highest price, lowest quality. Now you know why the Amazon boss is so rich.
5% tolerance on what metrics? Can you link me of an Audio Analyser that specifies a 5% measurment error? As far as I know, you can have an accuracy spec in dB, which determine the precision but thats not a Tolerance, it's simply the smallest step, and you of course have the limitation of self noise and distortion, but 5% is huge.Not really. Any decent measurement device will have less than 5% tolerance and such a low difference should nit reflect on the sound.
Company was quoted to say that they started with class D design but after two iterations gave up and switched to class AB.Trying to cram a class AB amp into a form factor suitable for a class D amp for marketing reasons is a recipe for disaster.
While many of their reviews do read like advertisements; I've also seen quite a few that say "better options at this price range". It is hard for that to be considered much of an advertisement.
It is indeed huge. I used that value to show that even if they had such a high tolarence, the audible result will not matter. Follow the thread to see the context of my reply.5% tolerance on what metrics? Can you link me of an Audio Analyser that specifies a 5% measurment error? As far as I know, you can have an accuracy spec in dB, which determine the precision but thats not a Tolerance, it's simply the smallest step, and you of course have the limitation of self noise and distortion, but 5% is huge.
Stop right there. You effectively learnt something.What I learnt; either what hifi is wrong...
I'm not an EE either, but a Class AB with a big transformer in a small amp is probably always wrong. A big class AB amp must be cooled.I'm not an EE but it seems like many of the issues with this unit could have been rectified by using a simple icePower module or something similar?
Class AB with a big transformer strikes me as a weird way to make a small amp in 2021.
I wonder what the problem was with class D? Too expensive?Company was quoted to say that they started with class D design but after two iterations gave up and switched to class AB.
An EE can better describe that, power, watts combined with class AB efficiency in %, how heat must be dissipated, how large size heat sinks are then needed.
Thanks for clarifying PMA.No, it is a matter of the design work. I designed and built this small class AB amp with LM3886 chips in 2009 (photo attached below), it had low idle consumption and quite nice parameters. 2x50W/8ohm, 2x65W/4ohm. You can make good or bad design in either class of operation.
The amplifier in this current review is really not good and the reason is a poor design.
There is nothing wrong with the new tpa3251 or 3255, hypex or Icepower. But before that , some solutions didnt sound as good as good class A/B . Especially not in the treble.I wonder what the problem was with class D? Too expensive?
It can also be that they wanted it to sound in a certain way, maybe soft in the treble ?Thanks for clarifying PMA.
OK, but let's just say, in the "context" of ASR, 5% difference on some metrics is enough difference to be the difference between recommended and unrecommended. Why are we even here? As for the "context" of the thread? I fail to see where it's obvious that you where discussing human audibility accuracy. I thought you where replying to me, I generally tend to think that when my comments are quoted before a reply.It is indeed huge. I used that value to show that even if they had such a high tolarence, the audible result will not matter. Follow the thread to see the context of my reply.
A SINAD about 80 in power amps is probably enough for serious listening. In dacs with volumecontrol maybe a SINAD of 100 is good enough to be transparent in home listening. But why be satisfied with less, if you can have a SINAD at 115 for less money ?OK, but let's just say, in the "context" of ASR, 5% difference on some metrics is enough difference to be the difference between recommended and unrecommended. Why are we even here? As for the "context" of the thread? I fail to see where it's obvious that you where discussing human audibility accuracy. I thought you where replying to me, I generally tend to think that when my comments are quoted before a reply.
It's a loaded question, it can also be turned around, we shouldn't side track too much on this, this is not related to this review, we can also say, why would a manufacturer spend engineering ressources on something that no one can possibly hear? I generally think that SINAD at 1K metric takes too much importance here, especially for amps. this 80 dB you mention, I'm not sure where it comes from, that's not how I assess the value in dollars of an amplifier so I can't answer.A SINAD about 80 is probably enough for serious listening. But why be satisfied with less, if you can have a SINAD at 100 for less money ?
Isnt it a bit different if you know the loudspeakerdrivers impedance in an active design where you can compensate ?There is a big problem of frequency response that heavily depends on speaker impedance frequency plot. In some cases of speakers, it easily makes 2dB at 10kHz and starts to deviate above 5kHz. And it is audible and distinguishable even in an ABX DBT test. No, these chips are not usable in a "serious" design.
NCore and Purify are OK. And even UcD seems to be OK, as its frequency response is independent of load impedance curve. Soon I will review UcD180HG HxR module.
