restorer-john
So either a complex modelling using analogue electronics, or accurately montior the current in a micro and implement in software.
The classic uPC1237HA SIP protector IC has been practically industry standard for around 35 years in analogue, conventional amplifiers and covers AC power on/off detect, DC offset trigger, over current (set by signal conditioning time integration RC or active), turn on mute delay and configurable reset/latch time. The IC is still made today and if correctly implemented, amplifiers using it are set and forget style protected.
Over temp wasn't really much of a problem in the good old days, because everything sold was compliant with FTC reqs, which meant overheating an amplifier in a domestic situation was virtually unheard of. Not these days, sadly.
Toshiba also had the TA-7317 SIP9 which is functionally virtually identical.
I'll take those ICs anyday over some stinkin' micro monitored system full of bugs and likely to lockup needing a firmware update when you least expect it.
