WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Thanks for getting back to me, Just about to look at that user guide now, I shl read the instructions!
If I need to change op amps I'll just get some balanced XLR cables. Just wiring it up now to test it out, found a old case from a previous project, it's a bit "holy" on the back but "it'll do".
You will have a drop in gain at the inputs if you use unbalanced to balanced cables (RCA> XLR)... It is not a question of changing the OP amps but of adding them in SE mode. The best is to use the module in balanced mode because it is natively delivered and optimized for this mode.
Looks like it has standby, so could be used to implement a trigger with a simple additional card. I have posted details elsewhere here. Here is the board…
Nice! I’m stoked to hear this, but more excited for the micro audio PS lol.
This is my first amplifier build. But I do a lot of DIY. Cables, speakers, motorcycles etc etc. Here are some pics of my latest DIY builds
I’ll have this looking sharp too.
Very nice Honda scrambler project, congratulation!
However twisting the spark plug wires would certainly bring some more horspower and wider soundstage of the exhaust system
Does anyone know what the actual dimensions of one of these amplifier modules is? The dimensions listed on 3e Audio's website and Audiophonics (105 x 90 x 38.5mm) appear to be for the older revision of the board.
50mm not less for me. Get a confortable margin for cables.... The Audiophonics AP300-S2503E amp is 300 x 220 x 65mm
Check my "Bamboo projects" all you need is there.
Yes, you are probably right. But the case is wide and I guess it's the caps that are 40mm. But I will look for another. I had it at home so it would have been convenient. Thanks @daniboun
Depends on the model ))) But if you want to drive this type of speakers with this module, I strongly advise you not to skimp on the PSU! believe in my experience....
@daniboun how difficult do you think it would be to replace the standard TPA3255 on the Wiim amp by the 3e Audio one? It may be a naive question but I honestly have zero experience with electronics.
