I can get skin hearing by shoving my hand in my speaker's reflex port.
Does it squeal with delight?
And this software is... ?since about two or three years ago, there is a software that can determine the precise % of portion of DSD that has gone trough any PCM conversion during its way from raw native DSD
Let's remain open-minded!I can't figure out how it would know.
Transient response will always decide in this case. And PCM - unless ridiculosly high sample rate, like DXD (356 kHz, IIRC ) and above, will lose out to DSD - flat out.
It does depend on the capabilities of the overall system, though ; if amplifiers and end transducers ( be it headphones or speakers ) can not reproduce approx "flat" to
at least 40 kHz, most of the DSD advantage will not be reproduced and thus not audible.
But, this is not the deficiency of the DSD ...
If parts of a recording have been manipulated and remodulated, it may be possible to detect the joins. If the entire track were converted to PCM and back to DSD, there would be no way of knowing.I can't figure out how it would know.
But as I suggested, let's remain open-minded for the time being.no way of knowing
OK, you could look at the noise spectrum and compare it to that of known modulators.But as I suggested, let's remain open-minded for the time being.
I have misplaced the info and had to ask a friend who alerted me to its existence in the first place - again.And this software is... ?
Yes, I understand it also this way. If joints are found, that means that native DSD has been edited trough some kind of PCM - but only in very short duration, slightly before and after the actual joint of two pieces. All the rest should be DSD. If entire file has been converted to PCM and edited/mastered in PCM as usual, what else knowing is needed - BUSTED !If parts of a recording have been manipulated and remodulated, it may be possible to detect the joins. If the entire track were converted to PCM and back to DSD, there would be no way of knowing.
How would you tell if the whole file has been converted? There won't be any splices to detect. Unless the noise spectrum is identifiable as matching a known software modulator, you'd never know.Yes, I understand it also this way. If joints are found, that means that native DSD has been edited trough some kind of PCM - but only in very short duration, slightly before and after the actual joint of two pieces. All the rest should be DSD. If entire file has been converted to PCM and edited/mastered in PCM as usual, what else knowing is needed - BUSTED !
I have yet to use the soft... - but, noise spectrum should be identifiable. As a matter of fact, noise spectrum change(s) alone should suffice to tell if the DSD recording has been converted to PCM only at splits - AKA DOING IT RIGHT.How would you tell if the whole file has been converted? There won't be any splices to detect. Unless the noise spectrum is identifiable as matching a known software modulator, you'd never know.
Nope - since idealized rosy glasses graphic presentations of pulse response of PCM vs DSD do not correspond to the actual performance of real world devices.At this point I'm left wondering, is there any tired, debunked, zombie canard about DSD vs PCM that you *won't* roll out?
So much handwave, so little actual evidence.Nope - since idealized rosy glasses graphic presentations of pulse response of PCM vs DSD do not correspond to the actual performance of real world devices.
Which is definitely not to say that they do not approximate them rather well also in practice - particularly in say RME ADI2 Pro FS. Used for real - not for RBCD.
How would you tell the difference between an untouched file and one that has been converted in its entirety?I have yet to use the soft... - but, noise spectrum should be identifiable. As a matter of fact, noise spectrum change(s) alone should suffice to tell if the DSD recording has been converted to PCM only at splits - AKA DOING IT RIGHT.
Otherwise, there should be no noise spectrum changes, meaning the whole file has been first converted to PCM, edited/mastered in PCM and only in the end converted back to DSD - aka DOING IT WRONG.
I'd put money on it.I'm certain if you get identical masters , 128 DSD and 96 PCM will be indistinguishable
It is perfectly possible that SACDs sound better on their PCM layer - and it is usually the hardware used for the playback. If the actual DAC used is optimized for PCM and has DSD more as an afterthought or "must check box", that is rather common. If the DAC used is about equally at home both in PCM and DSD (not to mention if it is optimized primarily for DSD ), then DSD will sound better.Iv always felt disappointed by DSD , all my 2ch SACDS sound better to me on the PCM layer , however that may be due to the crappy ' audiophile' mastering on the DSD layer .
I'm certain if you get identical masters , 128 DSD and 96 PCM will be indistinguishable.
Why is this still something we talk about ?
