Rja4000
I measured my
SONY PCM-R300 DAT recorder
The PCM-R300 was released around 1998.
(A review from the time may be found here)
This was the entry model in the SONY pro DAT recorders.
Obviously, this one is based on a consumer-grade DAT platform.
I purchased it second hand to replace my defective SONY DTC-670, and since I still had 60 DAT tapes or so.
It's much more advanced than the DTC-670.
I found it back in the box where it was stored for quite a long time.
It still works fine.
Test set-up:
Digital Loopback (48kHz) : RME ADI-2/4 Pro SE Optical Out > SONY PCM-R300 Optical in > SONY PCM-R300 Optical out> RME ADI-2/4 Pro SE Optical In
DAC (44.1kHz): RME ADI-2/4 Pro SE Optical Out > SONY PCM-R300 Optical in > SONY PCM-R300 Analog Out > RME ADI-2/4 Pro SE Analog In
ADC (44.1kHz): RME ADI-2/4 Pro SE Analog Out > SONY PCM-R300 Analog in > SONY PCM-R300 Optical Out > RME ADI-2/4 Pro SE Optical In
Software is Virtins MultiInstrument 3.9.8.1
Digital Loopback measurements
I was quite surprised to find that the digital loopback works in 24 bits, actually.
RME Bit-perfect test shows 24 bits bit-perfect confirmation message after transiting through the Recorder digitally.
SINAD
Jitter test 24 bits
Text-book perfect 24 bits Jitter results.
If something goes wrong, it's neither the SPDIF optical input nor the equivalent output.
Frequency response (44.1kHz)
EDIT: Now using a full bandwicth test signal
I also measured the digital loopback with a 44.1kHz 16 bits test signal
SINAD 44.1kHz 16 bits
This sets the maximum -perfect result- we could hope in 16 bits.
Mutlitone (16 bits)
82.7dB TD+N is the exact figure of the test file itself in 16 bits.
Recording and playback measurements
SINAD
I recorded 2 minutes of 997Hz test tone from Optical input on a random tape, then played it back through optical output.
Guess what ?
We get the exact same measurement than the loopback
Frequency response
Same for Frequency response
Multitone
Multitone is identical too.
DAC measurements
Of course, the DAC works in 16 bits only.
The DAT format doesn't allow more anyway.
SINAD
Distortion comes from the DAC.
It's H2 and H3, but level is around -98dB max.
Noise is reasonable too.
Overall, the DAC doesn't degrade the quality of the signal.
Noise
Except for some Mains peak and harmonics (I'm in Belgium, so it's at 50Hz multiples), this is quite clean.
(NB: 0dBFS on the vertical scale is for the measuring ADC. DAC maximum would peak at -4.7dBFS. Noise figures are vs DAC maximum.)
J-Test (16 bits)
EDIT: Re-measured. Original test signal was wrong
Here, we see some low frequency Jitter. Quite low in level though.
( To compare with state of the art values for 16 bits Jitter, you may want to look into my review of the Marantz CD6000 OS KI )
Dynamic range (-60dBFS - 16 bits dithering)
Note that when feeding the DAC with 24 bits, we can go up to 97.4dB.
But 16 bits is more relevant, since the DAT format can't record more anyway.
EDIT: Re-measured using a Fast Frequency Response signal from this page.
Multitone
We get a bit more than 16 bits here
Intersample overload
The DAC doesn't stand any intersample overload
At 0.2dB overload, we are already above 1% THD in this torture test.
ADC Measurements
SINAD
Input Level can be pushed up to >3.3Vrms, without improvement.
Dynamic Range
Multitone
Pushing the input level to 1.7Vrms, we get almost 16bits-perfect result
Noise
(level set for 2V recording.)
SBM measurements
Those SONY DAT recorder were coming with a technology called SBM, for "Super Bit Mapping".
This is a noise shaping technique which, according to Sony's claim, allowed to subjectively increase SNR or Dynamic range of a 16 bits recording.
You may find more explanations and links in posts below in this thread.
This technology only works at the ADC stage, when encoding to 16 bits format
Here, there is a switch to enable or disable it on the front panel.
All measurements above were made with it disabled. I was suggested to measure with it, so here we go.
Comparing with the above ADC noise, we see immediately the result: Noise is increased above14kHz or so, while it is slightly decreased below, and especially in the 3-4kHz area, where human hearing is more sensitive.
Comparing the 2 (zoomed 2x) makes it more obvious:
By the way, this is shaping the dithering noise.
It's not, like the old-ages Dolby NR, shaping the FR of the signal itself. So it has no impact on frequency response.
Nowadays, I'm pretty sure all mastering engineers are using a similar technique to shape dithering.
This old article from 2012 puts some light to this process.
Conclusion
Not too bad for a device from previous century.
DAT recording was the only reasonable way to record CD without too much loss by then.
When losses occured, it was brutal: Dropouts, complete loss of sound, due to errors...
This one as an "Errors count" display, that warned you somehow when the tape was bad and risk of loss increased.
DAT tapes are thin and rotating head quite fragile...
And then, of course, locating a track on the tape was SLOOOOOOW...
Those are the drawbacks of the DAT format, in general.
But soundwise, this one is a very competent device, IMO.
As far as 16 bits is enough.
Test set-up:
SINAD
Jitter test 24 bits
Mutlitone (16 bits)
SINAD
Guess what ?
Frequency response
Multitone
DAC measurements
SINAD
Noise
J-Test (16 bits)
Multitone
ADC Measurements
SINAD
Dynamic Range
Multitone
Noise
SBM measurements
Conclusion
