surroundman
- Joined
- Apr 24, 2023
- Messages
- 85
- Likes
- 95
I'll say what countless people said already ... this would have been an instant buy for me should there was an actual SUB OUT instead of that coax there ... sigh ...
Where did you see that? I have been looking for reviews for this amp for a couple of daysI have a question for those who are using AL200.
It has been reported that when listening to music or Youtube with USB input, pop noise occurs after starting and stopping playback.
Do you have similar symptoms with your AL200?
I own 2 of these intergrated Amps and don't have this problem.I have a question for those who are using AL200.
Thanks for the information!I own 2 of these intergrated Amps and don't have this problem.
It was information from user reports in my country.Where did you see that? I have been looking for reviews for this amp for a couple of days
So I guess for a desktop setup this little integrated amp seems more than capable then.It was information from user reports in my country.
After much research, I found no problems with the AL200.
I like to evaluate and test various products, and I predict that the AL200 will become popular, so I think I should buy it myself.So I guess for a desktop setup this little integrated amp seems more than capable then.
Sabaj does 2.1 with HPF filter on mains. Is that worth it to you? It is to me.The Sabaj 30a is almost 2X the price of AL200. Is the extra money worth the upgrade?
as always, depends on your setup. Sabaj a30a supposedly has more power if you want to play loud or if your speakers are not sensitive (like less than 85dB). also out of the Chinese manufacturers, Sabaj is said to be the best/most responsive customer service.The Sabaj 30a is almost 2X the price of AL200. Is the extra money worth the upgrade?
Come on...SMSL AL200 Integrated Amplifier Review
that is the DL200, i believe it's more expensiveObviously they changed or improved the AL200 at SMSL , the first version used a CS43131 DAC chip and now the AL200 would be under ES9039Q2M chip, and they added a 3.5 jack in front !!!
