New set of graphs for all speakers reviews
Arc Acoustics
Japan
Thank you for another fiddly tracing.
One thing I noticed is, Perlisten S/R4"s" is an on-wall type loudspeaker for THX certification, thereby the measurement is half-space.
(Strictly speaking, I do not see the interference caused by the back wall, so the measurement would be full-space and just ditch the rear hemisphere I guess.)
I'm not sure handling full-space measurement and half-space measurement in the same criterion is the right thing to do because I could not find the post-processing method in ANSI/CTA-2034-A.
(They might use the VituixCAD and if you use the half-space (in the option), VituixCAD will return hor+/-90° as the ER_Rear because they are the only component of the ER_Rear in the frontal hemisphere.)
It should have very similar characteristics (except for the bass) to the S/R4"b", and they have (both measured by Perlisten) so it may be not a big deal.
https://pierreaubert.github.io/spinorama/speakers/Perlisten%20s4s/Perlisten/index_vendor.html
P
pierre
Switzerland
Right. It is a windows app and thus doesn’t help me much. There is plenty of great app for data visualization that are open source and run everywhere.
krabapple
Pierre,
Thanks for this great resource.
Would you consider adding an column for speaker size -- floorstanding vs bookshelf vs center -- to the Spinorama ranking table? It would make it much easier to see e.g. which bookshelf speaker ranks highest under different conditions.
And since I'm asking, also a column for active/passive?
Also, can you add a 'sort by' function to the page?
P
pierre
Switzerland
Pierre,
Hello,
you can already filter and sort but that's not the exactly the same thing. Do you want the extra functionality directly in the table? I also have an export in a Google spreadsheet where you can slice and dice as much as you want if that helps.
Pierre
Here is an example filtering on center speakers and sorting by Score with Sub.
P.S.: I realize it is not super intuituve, if you have a better idea for the UI I am willing to change it.
kernelpanic
@pierre, came across your site today after it was mentioned by the Daily Hifi crew. Amazing job collecting and consolidating all of this data! Any chance you could add price as a search and filter field? It would make it even more powerful to search for speakers based on measurement results as well as budget.
P
pierre
Switzerland
Yes I can do it. That’s easy. Next time I get 2h I will do it.
Done :) You can now filter by price.
You can also sort by F3, F6, Sensitivity and Flatness.
Arc Acoustics
Japan
Found the slightest mistake.
(Both showing EAC (v1))
As usual, thank you for all these great works!
Edit: Klipsch RP-600M II should be "Grille off" and "Grille on", and KEF Ref1 Meta should be "Short port" and "Long port".
Arc Acoustics
Japan
Arc Acoustics
Japan
P
pierre
Switzerland
P
pierre
Switzerland
@pierre The data of Neumi BS5P on the chart is "port stuffed".
(actually, the data provided by @hardisj, who might be banned by some small ******* by the way, at the below link looks "port stuffed" only)
I think it should be explained cuz the data "port opened" is pretty much bad.
Hello,
I added back the note section (which disappeared when I revamped the website). It is here but not very visible.
Arc Acoustics
Japan
sweetchaos
The Curator
BC, Canada
Is anyone checking the veracity of the results on this site https://pierreaubert.github.io/spinorama/? Is that a completely false result appeared in relation to Elac Debut 2.0 b5.2 where it says "Bass extension: 200Hz at -6dB" this is completely false how can I believe the other results?
I would recommend that you look at the graph first
it's clearly a gated frequency response, so data below 200hz is missing.
The algorithm therefore assumes 200hz as the -6db point, which of course it isn't.
that's a negative way of looking at things. good luck with that.
HelloHell
Thanks for clarifying, but people who only see the result in the shortcut or don't understand measurements see all other speakers with bass extension at around 60hz 38hz and then look at the Elac measurement and think that this is 3.25" mid/woofer...
beaRA
I think I heard on a live stream that Erin would be measuring the Elac B5.2, so this gated measurement may be superseded for the data summary.
sweetchaos
The Curator
BC, Canada
Correct.
Erin has measured these and he said that they're not that good.
The data is not available yet on his website yet, but I expect that shortly.
He talked about it on *daily hifi podcast aug 29*, in case you're wondering.
P
pierre
Switzerland
hello,
Data is from Nuyes and that’s the first time I get data from him. we are trying to find a format that works well. His data is gated at 5ms so valid above 200Hz. Below that he
does a ground plane method. Fine. Except that merging the on axis and the other spl curves is not super pretty. Current result is:
Code:
Reading cache ... (loaded 1 speakers)
2022-09-03 15:51:57,767 INFO services.py:1470 -- View the Ray dashboard at http://127.0.0.1:8265
Queing 1 speakers for EQ computations
(optim_save_peq pid=816956)          SPK auEQ
(optim_save_peq pid=816956) -----------------
(optim_save_peq pid=816956) NBD  ON 0.31 0.20
(optim_save_peq pid=816956) NBD  LW 0.29 0.17
(optim_save_peq pid=816956) NBD PIR 0.30 0.24
(optim_save_peq pid=816956) SM  PIR 0.12 0.91
(optim_save_peq pid=816956) SM   SP 0.51 0.93
(optim_save_peq pid=816956) LFX       48   47
(optim_save_peq pid=816956) LFQ     0.41 0.58
(optim_save_peq pid=816956) Score    4.1  6.4
(optim_save_peq pid=816956) w/sub    6.3  8.6
(optim_save_peq pid=816956) +4.05 +6.38 Elac Debut 2.0 B5.2
you can also filter the speaker’s measurement by quality. High will only show klippel like measurements, medium will show good quasi-anechoic or anechoic data, low is everything else.
solderdude
The Neitherlands
@pierre First... great website. Never knew of its existence (totally missed it somehow)
What is the reasoning behind the blue bar for bass extension. Granted the numbers are displayed but I would consider 100Hz not 'extended' and then, by logic, I would the blue bar to be all on the left for 100Hz and for 20Hz on the right.
The same comment on smoothness. Why is the yellow bar not 1.0 on the right ?
Flattness a similar case why not have +/-10dB (which is terrible) all the way on the left ?
Just want to understand the reasoning. Maybe the scales are auto generated but see no reason not to fix the scales.
