Steve57
Tony, I agree with most of what you say above..Steve - what do you think fidelity is? What do you think distortion is?
Fidelity is defined as "the degree of exactness with which something is reproduced".
A perfect amp (perfect fidelity) is one where the output signal is exactly the same shape as the input signal, but bigger amplitude - zero distortion. (The proverbial wire with gain).
All amps distort to one degree or another. Distortion changes the shape of the output signal so it does not perfectly match the input. That distortion is a loss of fidelity .
(There is also noise, but we'll ignore that because it has little to do with feedback)
The only way to increase fidelity is to reduce distortion. They are simply opposites of one another. Any technique which reduces distortion by definition increases fidelity.
A simple feed back loop is a great thing, my comments is are about interactions within the amplifier to other signals.
My understanding is that feed back cancels distortion created within the amplifier, its a simple ? loop that cancels its own distortion
Any signal added from a 3rd source does not have an opposing distortion in the amplifier to cancel it.?
We know feed back is not a fix all, as you well know it works less well as you go up the frequency range. So higher frequency distortions are still there.
Feed back in many ways is a form of phase cancellation.. which should be an interesting subject to all of us guys
Phase cancellation is known in pro music trade as the silent killer..
Phase cancellation is well know in the recording and mixing industry.
But in my view can been seen to affect most amplifiers in various guises
