Hi audio noob here, I was looking at vertical contour plots to aid my decision in buying a speaker when I came across a curiosity of sorts.
Erin and Amir both reviewed the Wharfedale 12.1 with their vertical contour plots being nearly identical (±20). However Erin also additionally has a vertical 'polar plot' of his design which should show the same vertical directivity as ultimately it's a different expression of the original data. But he came to a different conclusion to Amir that the listening window is around ±5 degrees.
Here's the link with screenshots of the plots: This includes another example the ELAC Debut 2.0 6.2 but in that case I think Erin is being conservative with his judgement. However in regards to the Wharfedale I can't think of a reason for the discrepancy.
Lastly I have an active speaker (Kanto Yu6) hooked up to a Q Acoustics 3060s active subwoofer but the output is very quiet. It is a mono connection via the speaker sub out to the line level input on the sub. I have tested it with two different subwoofer cables.
I'd be thankful if anyone could offer their insights.
