In my opinion the best choice right now is buying an Anthem, will see the new models.
I had one, some time ago, and Arc works very well. Miles ahead of Audyssey XT I had before. The HDMI board fried when it was 2 1/2 years old though. I was pissed... I checked the fora and it seems that it's not a rare occurence.In my opinion the best choice right now is buying an Anthem, will see the new models.
Yes, this has me frothing at the mouth to be able to do all this! A screenshot would be much appreciated.
Are sure Heos onboad uses the lackluster network DAC set? I guess that makes sense, just trying to confirm. Thanks.
Thanks @peng Looks like an Audiolab 6000n will be on order soon.100%, because I have seen the block diagrams for the X4500H. Not sure about the X4700H though most likely the same. The PCM5100A is a stereo (2Ch) DAC, so Z2/3 network will be limited to two channel, in direct/pure direct.
Here's one that I just made up for demo. You can enter as many frequent as you want. Audyssey is still in charge of creating the necessary filters based on its own algorithm/methodology so you don't have to worry about messing things up. Unlike Yamaha's PEQ, you don't have to figure out the Q factors, because, again, the App simply allows you to do your own custom/house curve, and based on your target curve as modified by your manual entries, it will create the filters for you.
If you want to see some of the FR others managed to achieve using the App and the 3rd party Ratbuddyssey UI, I have users thread on AH:
https://forums.audioholics.com/foru...sers-thread-with-facts-and-tips.118005/page-6
Jon AA has done something wonderful in the high frequency range (see post#84).
Wouldn't HEOS use the network DAC?
Yes, right.
For DLNA and Amazon Music HD it’s going through the cheaper PCM5100? That seems like a lost opportunity.
It looks like the AV8805 has the same limitation with the PCM5100. For Amazon Music HD, it looks like Anthem with DTS PlayFi critical listening is the only integrated option.
Your reason for suggesting 2 subs even if the main speakers can handle the bass is because you can place the subs in the right areas to reduce room reflections and such?
Since many would intend to use the receiver as their streamer, would it make sense to have @amirm test the Heos input via roon/airplay2? If it is shown to perform relatively poorly this might be another area for improvement in future models. Unless I am not understanding this completely (always possible) it would seem customers should have at least as good performance on the streaming/music HEOS input as the other inputs. It is advertised as HD Music.. it would be nice to see how it tests as for many music is as important or more important than even home theater.I believe they all do, even integrated amps such as the Yamaha A-S801. If you have the service manual, you will see that the A-s801's also show a second DAC, the PCM5101 that is a little better than the PCM5100A. The RX-A AVRs also have the PCM5101, that's why I commented that D+M should at least do the same. Denon does have the best main DACs for their flagship models, comparable to Yamha's flagship's ES9026 Pro, better than Anthem's MRX-1120's that has the same AK4458 found in the entry level Denon's X1600H, not that it is bad, just saying.. People are going to say "but its implementation that matters..", true, but then why save a couple of dollars on the chip?
Note that Yamaha's RX-A3070/80 actually have 3 different ones, the best one for the main 7 channels, a lower model for the height/Atoms channels and the 3rd one for the secondary zones.
Onkyo does the same thing as D+M for sure. NAD appears to have two different types of DAC onboard too. Anthem like have done the same but I have not seen any SM of theirs so I am only guessing.
Notice how the peaks don't line up either indicating level errors versus frequency. This industry seemingly knows nothing about proper unit/corner case testing.
Not just that, but even if your main speakers did have 10/12” dedicated subwoofers your AVR amp would be severely strained to drive them properly.Main speakers cannot handle bass from action movies. Not unless they have dedicated 10" subwoofers on them
Buy a sub
Buy a sub
...Or organ music (Bach), synthesizer music (Hans Zimmer), electronic music (Daft Punk).
Buy two subs (minimum)
With this and the HDMI measurements in mind, I've built a RoPieee to use as a Roon endpoint and have ordered a Topping D50s.I would think that if you have a streamer that has better specs than the AK4458, and if your option is to use it with the Denon, then it is best to use the analog inputs and direct/or pure direct mode. If you want to use the sub, you can still set XO but no DSP/Audyssey.
