GM3
- Joined
- Nov 26, 2022
- Messages
- 142
- Likes
- 163
To briefly sum things up, got a new Fosi V3 amp to replace a 40lbs pro amp, "clean power is clean power", yadayadayada, heard differences, this being ASR, measurements. So goal of this thread being whether or not we can conclude anything about the amps in these set of measurements. (mostly in bass region)
Basically, I just set up a Blue Yeti mic a bit randomly; mostly relatively on axis, 1-2m away, at around woofer height, as I just wanted to measure the relative bass differences I was expecting seeing. (Although reflecting on this, tweeter level would have been better...). Room is quite lively...
Used REW, pink periodic noise, 1 speaker, RTA averaging. The SPL is likely off as no true dBmeter for calibrating REW/Yeti, started off moderately loud, last set was loud enough that it was getting annoying & I could see the bass woofer move quite a bit, but not super loud.
(The QSC has 30Hz protection activate which rolls the bass, but apparently might be kicking it at ~35Hz, as QSC rolls off far quicker <35Hz)
Attempt #1 With open port, V3 in orange.
Attempt #2, With blocked ports. Same location as #1.
This time, the QSC is in orange...
I realized that me being about 2.5 meters away might be affecting the results... So at this point, moved further away...
Attempt #3, moved mic & speakers a bit..
Green is QSC
Green = QSC (same as above, 1/12 smoothing, sorry REW kept switching colors...)
Attempt #4, moved mic around again a little..
Orange is V3
1/12 smoothing
In all honesty, I'm not entirely sure what we can conclude. I think mostly, results might be within the margin of error, and in some way, likely quite a bit of interpretation too in reading the graphs...
My 2c, YMMV, as I said, with ports blocked, I commented that I heard the V3 'struggle' with the ports blocked, seemed to have less bass. And #3 and #4 shows more bass between 35-80Hz with ports blocked for the QSC...
The graph where both speakers are closest together seem to be #1; bass ports open, which again corresponds to my earlier comment. But it could be coincidence as I didn't notice any consistency between the graphs for the amps... (ex; if blocked port altered V3 between 200-400 Hz or 1KHz or whatever, we'd see a consistent effect between different graphs, which I'm not seeing.)
So seems there could indeed be a bass difference; what the measurements seem to illustrate, but think I'd need more measurements to really confirm... Too big margin of error; more samples could help, but yeah, maybe the best I could do with my current setup... So yeah not likely super convincing...
Thoughts? Insight? Advice?
Green is QSC
Orange is V3
1/12 smoothing
