There is an Amp Pro in the works, but no Amp Ultra has been announced - although it does seem like a logical move to put a screen on the Amp.Will there also be an Ultra version of the Amp with a screen and bass management+ room correction?
There is always a better one next yearI‘m debating whether I should wait for a Amp with screen and all those other features or should just get the Wiim Ultra and use my Denon integrated as a power amp.
Best wait for the Ultra Pro PlusShould I buy the Ultra now or wait for the new Ultra Pro ?
I wonder if you will ever be able to make a decision on your own and finally buy something....Should I buy the Ultra now or wait for the new Ultra Pro ?
If you have a quality DAC the Wiim mini does everything you need for $90.
The features they are adding are really unneeded.
The Wiim amp is OK. But you can easily use a better quality amp with the Wiim mini.
The Wiim Pro Plus is nice but if you have a quality DAC like the RME ADI-2 you're still going to use it's loudness feature, balanced outs and such so you end up using the plus with optical out just like the mini.
The Wiim Ultra will give you a screen but those using Audirvana on MBP don't need it anyway...
Bottom line - New Wiim models raise price for solutions that can be done better with a separate DAC and amp.
The Wiim mini is the best value and actually all you need for streaming.
The Wiim Amp is more than just a mini with a power amp though, it has more comprehensive inputs outputs and a sub out with bass management. If you can find a separate dac/pre/power amp with those features for less than the Wiim amp I'd be astounded.If you have a quality DAC the Wiim mini does everything you need for $90.
The “Non Plus Ultra”Should I buy the Ultra now or wait for the new Ultra Pro ?
I emailed them and it looks like they’ve amended it and removed the higher quality codecsThat's why I have doubts. It's from Audiophonics webpage but I can't find it anywhere else
I’m sure I read somewhere that someone asked them at the Munich Show and were told something like that might be in the pipeline but no projected date nor price were given, so I guess you might take that info with a pinch of salt.There is an Amp Pro in the works, but no Amp Ultra has been announced - although it does seem like a logical move to put a screen on the Amp.
I though that most people around here think that there wouldn't be an audible difference between the DAC in the Pro Plus and ore expensive DACs like the ADI-2 or many others?The Wiim Amp is more than just a mini with a power amp though, it has more comprehensive inputs outputs and a sub out with bass management. If you can find a separate dac/pre/power amp with those features for less than the Wiim amp I'd be astounded.
Wiim Pro Plus is very difficult to beat, value-wise as well, if you don't already have a DAC. It won't compare favourably to a Pro and ADI-2, but that combo is roughly 5 times the price of a Pro Plus. Add a separate DAC to a Pro for less than the roughly £70 difference between it and the Pro Plus and you wouldn't be getting anything better.
I am personally planning on replacing a Pro and separate DAC with the Ultra because of the screen, HDMI arc and sub out. These are features which add value for me and I think the Ultra looks fantastic as well.
The ADI-2 has a myriad of features not found on most DACs. The loudness feature seems to be very well thought of. By the same token the Pro Plus has features the ADI-2 doesn't, so it depends on your needs I suppose.I though that most people around here think that there wouldn't be an audible difference between the DAC in the Pro Plus and ore expensive DACs like the ADI-2 or many others?
The EQ on the Pro Plus is actually pretty nice after 20 years without any tone controls or EQ on anything (blame that on Naim)! EQ make total sense given room nodes, etc and I find it adds quite a bit.The ADI-2 has a myriad of features not found on most DACs. The loudness feature seems to be very well thought of. By the same token the Pro Plus has features the ADI-2 doesn't, so it depends on your needs I suppose.
Without EQ/loudness etc they would sound exactly same.
The EQ on the Wiims is brilliant IMHO. I wasn't knocking the EQ, just pointing out that without using any it would sound the same as the ADI-2.The EQ on the Pro Plus is actually pretty nice after 20 years without any tone controls or EQ on anything (blame that on Naim)! EQ make total sense given room nodes, etc and I find it adds quite a bit.
