Too much. In the cardboard box is the DSP (so I can protect it from me being an idiot). It has it's new power supply (in the unshrunk shrink tube) as the onPCB regulator died. Along side the UI dev bed. Which as you can see from the random gibberish "volume" value is coming along really well (sarc).
On the left is my complete mess of 12V/5V USB and DC wiring running off that little power supply (coming from the solar LFP 12V garage system)... and the 100Ah Marine lead acid "buffer battery" on the floor... which is about to be capacity tested this weekend with the colourful little gizmo. Out of shot the internet router and network switch are running off said lead acid. It itself is a temp surrogate for a new "Audio lab battery", a 6S LiFePO4 battery, which I will multi-tap for a range of voltages including -10+10.
My little blue 1.5 Watt headphone amp glowing nicely.
(Yes, that feed does come in through the wall via a 6mm cable ... and I tap it with croc clips. It's 12V FFS. It's fused at 15A, if the cat shorts it, the fuse will blow.)
EDIT: ON protecting the thing from "me". This week I am healing a nasty blister a whole in my pocket and feeling dumb. I set said new power supply on top of the MCU board. It was powered off of course. Not that dumb. Until later on, when I switch it on and didn't immediately play any music. So I didn't notice it was shorted. When I did notice I lifted the PSU board off the MCU and immediately dropped it because of how hot it was. Being even more dumb I then put my finger on the MCU itself to see how hot it was
. It now bears the tattoo of my fingerprint and I lost about 1mm of the skin off my finger . I figure it was just below glowing orange 300+C. £40 replacement.... already in stock.
Not two nights later I put my multimeter into the mains outlet of an inverter on the wrong setting and fried it. £100 replacement. Meter "should" have survived it, but due to design/wear and tear it failed to.
EDIT: The MCU in it's shorted state was consuming 1.6A at 12V. Most of that heat seems to have been centred in the exact point I touched.
