This we do not know, as there is no information about the input module. Are they regular opamps that amplify the signal, or is it a differential amplifier?But this is not how the PA5 works.
ice module. All of them I have heard were terrible. 30 year old design. I hope for them I am wrong, but the PA5 seems to be todays most current design.That looks very interesting, I'll await a review hopefully from Amir.
it will drop power by about 40% assuming the RCA outputs deliver 2V max. Power is not volume. you need approx 10x power to perceive a doubling of volume. 40% less power (about 2.2 dB) will typically be perceived as about 11% drop in volume
I'm just going by the instructions and specs per the user manual. Ask Topping what they think it means.What do you think balanced even mean?
Should not make any difference.This we do not know, as there is no information about the input module. Are they regular opamps that amplify the signal, or is it a differential amplifier?
Again?Ok, Single ended input, so it is still a really sweet 20W amp.
It doesn't matter. The amplifier applies a gain of around 19dB from input volt to output volt. With a 2.6V input, and the gain of the amp, it outputs full power (just before clipping - or perhaps at the 1%thd level - I'd need to check to be sure).This we do not know, as there is no information about the input module. Are they regular opamps that amplify the signal, or is it a differential amplifier?
50W -40% is 30W. And that well below the clipping level, so very clean. You still seem hung up on 20Ok, Single ended input, so it is still a really sweet 20W amp.
No.OK… It will drop the volume by X and X is audible…
No its not about terminology or being pedantically. You got it completely Wrong.being consistently pedantically called out by terminology
Hint it is not what you think it means.I'm just going by the instructions and specs per the user manual. Ask Topping what they think it means.
Lines carrying symmetric signals (those with equal amplitudes but opposite polarities on each leg) are often incorrectly referred to as "balanced", but this is actually differential signaling. Balanced lines and differential signaling are often used together, but they are not the same thing. Differential signaling does not make a line balanced, nor does noise rejection in balanced cables require differential signaling.
The problem with using the wrong terminology, is you misinform others.OK… It will drop the volume by X and X is audible… seriously, I give up trying to help anyone here and being consistently pedantically called out by terminology
To a Purifi challenging amp? Fantastic promise!... where do we go from here?
There IS a market for the PA5, at reasonable price.Topping now realises they are not selling even a single PA5. Everybody waiting for PA7 or PA9.
Its about 160 V/A, that roughly matches its top power both channels driven. A bit close to the ragged edge.The size ratio of amp vs. power supply looks a bit crazy .
Considering power supply, is this combination of 38V 4A used also with some other electronics, or is it unusual rating specific to this amp?
To nitpick a bit, I don't see efficiency numbers at Topping power bricks, is it not compulsory at least for EU market?
PS: all you folks screaming for teardown two seconds after review, I know you don't mean it, but it sometimes seems like Topping/John is some DIY/opensource buddy from your neighborhood without will/right for at least some amount of intellectual property.. should't he publish all the technical documentation right now for us and Topping rivals?
Are you planning on replying to one post on every page of this thread? If so, you might be here a while.Its about 160 V/A, that roughly matches its top power both channels driven. A bit close to the ragged edge.
I only follow this thread occasionally, with what then 20W? The effect Amir has measured so, .que?What is the point of going around saying it's a 20w amp if you're not going to explain why?
I don't understand your question. o.oI only follow this thread occasionally, with what then 20W? The effect Amir has measured so, .que?
effect is a mistranslation (I think) from Swedish. Meaning power.I don't understand your question. o.o
Sorry, it went a little wrong.I don't understand your question. o.o
I paraphrase (apologies to Daniel):
"What the hell are (people) going on about 20W. Amir has measured the power here"
