Amir probably measured power for a balanced signal. However, 20W may be the power for an unbalanced signal. Unless a bridge amplifier like the TPA 32XX is preceded by a differential amplifier, transformer, or other circuit feeding signal to both halves of the amplifier.
Balanced or not,. Then Amir must describe how he did. I had actually started thinking about it. Not because I need it right away, but still. PA5 which takes care of everything over 80Hz could have worked for me but with 20W not a chance in hell that I would connect an amplifier with so little power in my main system. That is not enough.
Edit:
Also, PA5: US $ 349/20 = 17.45
Compare with:
Hypex NC400 DIY Amp, 225 W
"So putting aside labor, it's about USD $ 1,100. From outside, the unit looks very professional, without branding:"
USD $ 1,100 / 225 = 4.88
This is a review and detailed measurements of a DIY power amplifier based on Hypex NC400 amplifier modules. It was built and is on kind loan from a member. I asked him to list the parts and this is what he supplied: $980 Amp modules, SMPS, internal cables (AC, DC, and shielded input) with...
audiosciencereview.com
Okay not quite fair because the Hypex is a DIY, but still.
When I'm still into this with fixing .If you do not need so much power. NAD3020 and now I'm talking about the classic model. Full service and recap (if needed) on one. If now PA5 only has 20W then I would choose a NAD 3020 every day of the week. It also has more functions, more inputs, possibility with pre out.
Edit:
By the way, if you are young and can hear the really high frequencies then the choice between PA5 vs NAD3020 is also easy to make.
But think about this!The transformer in the NAD3020 can hum. I got annoyed at mine and tried to put rubber plasters between the chassis and the transformer, extra screws as well. It did not help. I got tired of the hum and then sold it (the buyer was aware of it before buying).
Apart from the highest frequencies regarding SINAD PA5 vs NAD3020, then NAD3020 does not have a chance against PA5, I think. However, when will it be audible (THD + noise)? Okay it was OT, some other time, in some other thread it can be addressed.
Edit 2. OT:
Buying old vintage, without being able to fix, service, recap and so on or have a friend who helps can be expensive, quite expensive, if you hand in the stuff to a professional repairman who charges per hour.
