solderdude
Don't worry... these days almost all devices sold use USB-C cables so you may find a use for it in the future.
Good to hear a FW update solves this issue.
Got it. Thanks.Lol no. Just trying to be clever with the words, saying “super fast” and then following up with “keep up”. If it sounds condescending then I have failed at it so apologies.
Thank you for the information.My apologies for not keeping up
I had not a device that uses Type C nor a Type C cable in the house.
Lots of manufacturers includes accessory cables with their products. Just thought it would have been nice if Topping included a cheap one for FW updates.
They included a bridging jumper cable, why not a USB FW cable?
Anyways, I went out to Best Buy and purchased a type C so I could do the update and all is well. But I have no other use for this cable...lol.
Testing is a forgotten disciplineit would seem so, which is good news, I just wonder how a product that has just come out has such an obvious bug, which then, it had many functions, maybe I could even understand it, but it is an amplifier with a power button, a volume knob and three inputs, stop.
It reminds me of when mass effect 3 came out (for video game lovers), which by default had a bug that didn't start a mission, and even then I wondered how a new, supposedly tested game could have such a noticeable bug on release.
When the designer group is also the tester and often even the support they can’t put themselves in customer’s shoes. Testing and support should be separate but it hardly is these days of “efficiency”.Why on earth is the firmware upgrade process not designed so that it is impossible to flash a firmware not intended for the product.
But should any of this negate common sense?When the designer group is also the tester and often even the support they can’t put themselves in customer’s shoes. Testing and support should be separate but it hardly is these days of “efficiency”.
Oh how I wish they stopped I have kilograms of now mostly obsolete mini- and micro-USB cables and surplus 5V charges lying around the house. Seeing how every supermarket has those, the cable- and charger-free should be an option for every electronics purchase, unless the device uses some unique proprietary connector or PSU.Lots of manufacturers includes accessory cables with their products.
Valid point.I hope the EU mandates it or something, the amount of waste globally is unimaginable.
I'm sorry, I don't know what "running strings" is.
Got the file, strings doesn't tell me anything of value. Hexdump tells me the file starts with PDPT:Strings is a Unix/Linux command-line utility (MacOS too) that extracts ASCII strings (text) from a file. He’s asking what text strings or symbols are in the firmware update. I’m curious what embedded architecture they are using myself!
kst@tecmobile:~/Downloads/LA90_FW13$ hexdump -C LA90V13.Topping | head -n 4
00000000 50 44 50 54 13 00 00 00 7c 2a 00 00 ce 27 0f 00 |PDPT....|*...'..|
00000010 7f 0c 81 92 ba ac c9 11 e4 53 5e 1e a6 bc 46 27 |.........S^...F'|
00000020 cc 61 3a 7f d2 96 b3 c2 38 98 27 5e 71 28 7d d8 |.a:.....8.'^q(}.|
00000030 93 15 9a ef 4b cb ab df 9c a5 58 32 db 30 c0 dc |....K.....X2.0..|
kst@tecmobile:~/Downloads/LA90_FW13$ file -ki LA90V13.Topping
LA90V13.Topping: application/octet-stream; charset=binary
Well, i think any modern mass produced AB amp has a microcontroller to monitor for different things such as temp or shorts, switch on/off relais and so on.why does an AB amplifier need software and updates in the first place?
Shouldn’t but they get blinded by their own development chores. Topping is nowhere near an exception in this.But should any of this negate common sense?
I think we are forgetting the ignorance or inexperience option here too. Everyone seems to think they are doing it knowingly. I believe most of this is due to lack of experience. Seen it happen many times in both hardware and software productsShouldn’t but they get blinded by their own development chores. Topping is nowhere near an exception in this.
I imagine it is a mixed bag with Class AB power amps. Do old school designs like Outlaw M2220 or NAD 275BEE or Anthem P2 or ATI1822 have microcontrollers? I don't know the answer but surely some go just fine without needing "smart" control.Well, i think any modern mass produced AB amp has a microcontroller to monitor for different things such as temp or shorts, switch on/off relais and so on.
The future is now, old man.
Oh, you will if you buy any other smartphone, USB dongle, USB power bank, etc. You'll need it.My apologies for not keeping up
I suspect any with robust fault control have a microcontroller or more. It's the best design solution for managing complex fault logic, blinking LEDs in response, etc. It also supports updatable logic via firmware images.I imagine it is a mixed bag with Class AB power amps. Do old school designs like Outlaw M2220 or NAD 275BEE or Anthem P2 or ATI1822 have microcontrollers? I don't know the answer but surely some go just fine without needing "smart" control.
edit: well I'll be damned the NAD does have a microcontroller. Maybe I'm wrong and they all do. Anyone know?
Did new firmware fix the one that went into protection? @Selkirks ?Since the issues with the LA90 appear to be firmware-related and not indicative of poor QC (other than firmware testing), I have restored my “Great” ranking in the poll.
Obviously I can't speak for Selkirks, but mine went immediately into protection (blinking front LED) at the very first time I powered it up.Did new firmware fix the one that went into protection? @Selkirks ?
