Topping LA90 Review (Integrated Amplifier)
Rate this amplifier:
    Votes: 35 4.4%
    Votes: 50 6.2%
    Votes: 193 24.0%
    Votes: 525 65.4%
daniboun
France (Lyon)
For those who might be interested, I ordered my LA90 in Italy, in stock in Silver and black version with a discount of 50€ with a promo code :) (
I don't know if the promo code is valid for a long time)
promo code : NEWSLETTER
Can be shipped in many ways )
thin bLue
Reviewer
Great job again! @JohnYang1997
May I ask numbers of LA90's energy consumption @ idle, and if it has standby modes, what watts @ standby?
daniboun
France (Lyon)
So there we have it.
The challenger came in with some fancy foot work.
The AHB2 is still Champ by TKO.
Thanks DT
can you develop? champion in your ears or proven champion?
tritopia
I am using two amps, SMSL SA400 and Topping PA5.
And today I added Topping LA90!!!
First impressions are good enough. :D:D:D
daniboun
France (Lyon)
Got first info : The LA90 is using a LM3886 inside.
About the LM3886 :
Same chip as the Neurochome )
Maybe same topology : composite amplifier ?? )
pma
Prague
About the LM3886 :
Hmmm ….. , as expected.
Tusoli5
Made quite a bunch of LM3886 chipamps and really liked their sound in mono chip. Prefered it in dual triple triple chips per channel as it was more stable and efficient.
But, in mono chip its power always was quite enough for 86db speakers.
In dual mono it was very revealing and easy to listen.
If topping managed such results with low noise and low distorsion, it can be a very good amp to try.
DualTriode
About the LM3886 :
How do you know this? Do you have a photo?
I first speculated a composite amplifier in post #835.
Are you sure that it is not a TDA7293 chip?
DT
jrosser
DualTriode
TDA7292 would make the pin count 15 rather than 11?
Looks like 11 pins from the photo all the way back in post #292
Progress?
Anyone with a up close photo that identifies the chip?
DT
Edit:
Looking at the photo I see what looks like op-amps down in there. Error correction?
daniboun
France (Lyon)
DT
Got the info from L7Audiolab (author) I think he knows what he's talking about)
That being said, we will quickly find out when we have pictures of the innards of the beast. )
Something almost sure, the PSU is a Bipolar SMPS @ 32-02-32V @3,75A
And here are some pictures with the original box which is nice) Dell XPS PCs are delivered with the same type of pacakge) You can also see the size of the power supply) :
DAC = Gustard AK4499
daniboun
France (Lyon)
daniboun
France (Lyon)
Updating the firmware to v1.3 did nothing to resolve the issue I had with the LA90.
That s why I mentioned : "Find it really unfortunate that Topping does not stipulate the list of fixes..."
Reading the plan below, we guess that it will be necessary to disassemble the case from the front. The ventilation holes let us guess that there are people under the box)
For those who own the LA90 : we see 4 screws towards the corners and I imagine that the two screws in the center must hold the PCB in place
In my humble opinion it will be necessary to be satisfied with pictures taken from the front side =) I'll try to dig a little deeper into the subject knowing that I don't want to void the product warranty...
BTW the Sinad list is now up to date )
pjug
You would think so with the three pins, but Amir checked it and it is +64V, with the other pin no connection.
nagster
Congratulations to all of topping. Keep going further.
board, power consumption, temperature.
solderdude
The Neitherlands
Pictures below show this as well 64V only.
This means the amp is either bridged on the output or there is split power supply in there.
The obligatory connecting of - outputs to enable bridged operation suggests the amp is already bridged inside.
Maybe the LM317/337 have something to do with this but these are current limited below the output current capability of the amp.
2 of these in parallel would limit the LF output current to 3A, for higher frequencies the power supply caps could provide extra current.
Too bad the one that took it apart and found out about the LM317/337 did not show the power amp part number(s).
Would be fun if @JohnYang1997 would give some hints about the internal structure.
