I am not sure he is reading, and if he did, not likely that he will respond.(maybe the gentleman of the video reading us and can enlighten us a little?)
Just curious, have you measured the platter ups and down at the outer rim? I've tried it on my Linn platter and it might be in the range of 0.2-0.3 mm.The problem is that this platter was designed a long time ago. There was no Internet, smartphones, etc. back then. Nobody recorded Technics platters spinning crookedly, even though they were spinning just as unevenly, and sometimes much more, and didn't post the videos on the Internet.
There was also a greater tolerance for less precise workmanship, because the technical level was less advanced
They came up with such a platter design over 40 years ago, the platter became iconic, well-known, recognizable. There is no 1200 model without this platter shape, it is one of the most important recognizable features.
And there is a problem, because it turns out that they can't, or it is unprofitable for them, to make the platter and bearing so that they spin evenly.
They don't care, it's been 7 years since the debut of the 1200GR, and they haven't improved it at all.
Just what models are we talking about? I took it to mean all 1200 models....and isn't an issue with my mk2.It’s a reality of the process - the platter is cast, and then machined to true it up, so the placement of the strobe dots is from the mold and thus they’ll never be perfect. As long as the interface and running surfaces are true, it has no impact on performance.
I just looked at mine, don't see such.Any with a cast platter of that style.
It was sounding more like "all" in this thread. If widespread on the re-release of the 1200s, that's a shame. I never heard of this issue before this thread in any case. I've had mine since '85 and belong to a 1200/1210 group on FB. Might post it there to see if it gets much traction....That doesn’t mean none do, just as some doesn’t mean all. It’s variable.
Record a video of the platter spinning in your turntable.I don’t see any wobble in my 1987 mk2
in what proportions are these differences? have you exchanged the platters? level ? lubrification , tighter tolerances on axis/well etc. etc etc. ?I have two copies of this turntable.
The second one does not have such good WOW parameters. I made several measurements, with the same smartphone, and I did not manage to get such a good result of the WOW parameter as in the case of the first copy.
I deliberately bought 2 copies of this turntable, to choose the one with the better WOW parameter.
In both copies, the platter spins the same, visually unevenly
HA! That Continuum thing with rippled record/mat and the pickup stylus bouncing alarmingly on its suspensionHi,
So, which one has the platter that makes the most waves? The Technics from 1:50 or the Continuum Caliburn from 9:16.
For me the machining quality of the platter is identical, I'm not talking about the intrinsic quality of the turntable, everyone knows that the Caliburn is a fantastic high-end. No one will come and say all year long that the Caliburn's platter also oscillates. Many turntables give this impression, of an intoxicating platter, without the information leaking constantly on the net and without it harming their sound quality.
NB: for the Caliburn, don't look at the black disc, but at the chrome platter, it oscillates more than that of the 1200G presented in this video: it's factual
Just like my early 70s Dual 701's Pabst motor -The weight of the plate is 2.5 kg
The bearing, although it has the same construction as in the GR model, is made differently.
The problem is that the MK7/GR/GR2 model uses a very old, but still common, technical solution, mounting the plate to the engine axis. In addition, it is made imprecisely.
The G model has a completely different engine, a much better mounting of the plate to the engine (additional screws) and the additional bearing works in oil. A different class.
OK – the platter discussion inspired me to do a quick&dirty video with my 1978 or so Sony PS-X60:
Dropbox
www.dropbox.com
Could you measure the wow parameter with a smartphone placed centrally above the motor axis?
Made a quick attempt to do that the other day and I was fine with the results:
