Technics SL-1300G New Generation Grand Class Turntable
I was mainly relating to the then audio press and belt drive manufacturers used the inaudible (to most) cogging as a reason to buy their gear. Now, subtly, Technics is saying "we rectified that (even though it was not a real world issue for most people) now our gear is better than ever" that they sure used the negative that others said & turned it around. Great marketing, after leaving the market totally for a while. Take a non-existent negative, fix that "problem" so it cannot be an imagined "problem" & now: 'better than ever'.
The peeps in the link made a pretty good living modifying the Technics 12** mk2 models and I maintain that *some* of the thinking was sound, as regards the under-platter mains transformer removal (my SL1500s have the transformer shielded and under the deck plate) and maybe the performance of the regulators used. They even did one mod which reduced the torque a bit, but you can decide if that was fashion or a genuine 'improvement.' There was an entire thing on the ArtofSound site once regarding heavy platters (then very light ones) and all sorts of jiggery-pokery to this deck that hobbyists love. I can't be a*sed with this sh*t any more ;)
In the USA, I have personally had some good results with these folks regarding Technics Turntables.
There is quite a bit of DIY available from them, too. So peruse their catalog of gear.
There is gold, too, so that the pollen can be matched when the black is covered in it.
(My heating and AC system uses the same filtration as the space station does and I have 2 large industrial HEPA filtration systems in my home [my wife has allergies to the pollen in this area]. But, from the street, you cannot find my home due to the camellias and azalais that are as tall as my roof (+ the 4 steps above ground that my house is).
No, I did not grow them that way and they were not blooming when I moved in. After the blooming season last year, I cut the ones close to the house down to about 6 feet.
That did not help much from the viewpoint of pollen getting into the hose when we enter or exit.
Since I am only here for a few years, I don't think that cutting them down to the ground and digging the stumps up and burning them is a great idea BUT that is what I would do if I were going to be here permanently.
I bought many really expensive turntables, but as long as they went around at the correct speed, fitted with the same arm and carts hardly any difference.
At one time I used these two Technics SL12 ‘Monarchs’ same table same arms, different cartridges, same two phono stages , I found it interesting interesting but customers seemingly not so much, suspect they would prefer to ‘believe’ .
KeithView attachment 390776
They look wonderful. I would have had fitted acrylic covers made for them, though.
Love the discussion in this thread of magnesium used in the highest-end Technics tonearms. U-Turn sells turntables starting at <$300 that use a one-piece thixoformed magnesium tonearm, so let's dispense with the idea that magnesium is some sort of high-end, unobtanium finery in such applications.
Technics is gorging on the fat wallet audiophile crowd with their current offerings.
My 1984 Technics SL-M3 uses a titanium nitride tone arm...Just wondering?
OK:
Technics SL-1210G Grand Class at Crutchfield ($4,299.95, backordered)
It doesn't get much more mainstream than this.
I'm with you on the audibility of this stuff above the level of the level of my SL-1500C. The 90/10 rule still applies.
But the notion that these prices are outlandish in the landscape of audio products seems unsupported by Technics' own price lists from the 1970s.
I do like the way that Technics Marketing department attacked the myth that there was an audible problem with "cogging" according to the rubber band types and "fixed the non- existent cogging problem" to successfully out market the rubber band TT companies.
The modern Technics SL series it totally modular: it is the same TT all the time with different bits and pieces, with a series of "upgrades" or "features" to adjust the price to the user's propensity to spend.
I just bought a SL-1300G, I originally got a SL-1200GR2, which seemed just fine, but within a couple of weeks it developed a PS ticking issue. Also I found the speed slider and the strobe light quite obnoxious on the 1200, so I decided to splurge an extra $1.5k to have a version without it.
The SL-1300G is pretty much the same as SL-1200GR2 in every aspect, but with a heavier platter and a slightly different motor. And without the silly speed slider.
Do I care about the heavier platter? No, I think it is marketing BS. I would have preferred a slightly better arm instead, but for that you need to get a SL-1200G, for an extra $1k, and you're back with the strobe light and the slider :rolleyes:
In retrospect, getting the SL-100C ($1,4k) would have been just fine, it has the same base and the same tonearm of the SL-1300G, without the extra fancy platter and would have cost $2.6k less...
Reactions: EJ3
I have issues with the DJ controls - don’t like the appearance - which is why I went with the 1300G. After 1.5 years of use - rock solid and without a doubt the best turntable I have owned. The only differences between it and the 1200G is the lack of DJ stuff on the 1300, the better motor controller code on 1300, while the 1200G has more mass in the chassis. The 1300 has the same dual rotor motor and multilayer platter as the 1200. It was the “sweet” spot in their lineup before tariffs bumped the prices - it still is but cost more now. Don’t discount the heavier multilayered platter - these things make a difference in mechanical systems. Edit - forgot the 1200G has the magnesium wand tonearm. Not quite a "drop in" replacement. I find the stock tonearm quite sufficient.
