- Thread Starter
- #281
I'm testing right now 1.0.4 Build 001, which like I mentioned before, is a Beta firmware that is fixing some network related bugs and introducing new functions.
I was testing 1.0.4 and today i had again the freezing issue after days. The same for you or not?I'm testing right now 1.0.4 Build 001, which like I mentioned before, is a Beta firmware that is fixing some network related bugs and introducing new functions.
I also encountered the problem with 1.0.4. The build003 version is loading.
But all updates are very long since the update integrating ma remote.
The remote control supplied with the xsabre is not operational. The battery drains immediately...it is unusable. @MatrixAudio is considering something because the new RM4 remote control is expensive.
No issues with their new firmwareAny updates on these bugs?
Are you going to send it to him?@amirm
Review this, man.
@amirm
Review this, man.
I noticed some weird distortion patterns and channel imbalance and want to verify it.Are you going to send it to him?
Anyway, I did the job, already:
Matrix Audio X-SABRE 3 Measurements (DAC & Streamer)
Matrix Audio X-SABRE 3 Measurements Hi folks, Here is another review, measurements-based, of the Matrix Audio X-SABRE 3 DAC and streamer. This unit has been kindly loaned to me by @Audiophonics for the purpose of this review. This is the third version since the original X-SABRE Pro, which...www.audiosciencereview.com
The latter isn't a streamer, so: no.Does anyone know if it applies to the older Sabre Pro MQA?
