Do I need a physical volume control in my setup? If so, should I just change my streamer?
dan_uk
Hi all,
I have the following and am very happy with the sound quality, however, the only volume control I have is digital via Roon.
  • Allo USBRIDGE - Network into USB transport for Roon
  • Matrix Audio X Sabre Pro MQA DAC
  • Nord One NCx500ST Stereo Power Amplifier
  • REL Storm sub - Connected directly to the Nord for high-level input into the REL
  • Monitor Audio Platinum PL100 ii
I'm super happy with the sound, however, I'm always concerned, what if Roon decides to set my volume to 100% somehow? Is this possible / a valid concern?
I don't really want to add a full on pre-amp, seems OTT as I only really have one input and what affect the sound? What about adding a passive pre-amp with just one input/output and a volume knob?
Lastly, I also wouldn't be against the idea of swapping the Allo transport and Matrix Audio DAC with something like the Eversolo A6 or A8, a streamer, DAC and volume control all in one?
Thanks, everyone
I call the pre-amp as volume control. It supposed to be less than $50. It’s just a volume control, which is said by a lot of people as Pre-Amp.
Your Matrix Audio DAC has volume control as well.
Why not set your Matrix so that 100% in Roon is just loud enough? Use it as a limiter basically.
Ah good idea... So switch DAC to pre-amp, turn the volume down... Crack up Roon to 100% and then increase DAC to the maximum volume I'd ever want to listen to... Then just use Roon on a daily basis.
I assume the Matrix Audio has no history of resetting its volume to 100%?
I don't know.
It's much easier to slip with your mouse and set a software slider to 100%, than it is to keep holding down the Matrix's volume button though.
I don't know.
Thanks @staticV3 !! HAve been running like this for a few days now and works a treat!! I think generally I'll be running Roon at -20 db most days, so even if the DAC does reset to 100%, at least it's better than Roon and the DAC being at 100% together!
