- Thread Starter
- #401
As for the z-offset delay, there is a pretty good minidsp app note on how to measure it. You need to have all your wiring done correctly and use the analog input. Inputs 1 and 2 are left and right respectively and outputs 1 and 2 are the tweeter and woofer respectively. With this wiring, the minidsp routing should be thus:
Setting up the sweep with a specified acoustic timing reference, after you do your measurement, go to the impulse graph, click on the box on the upper left and change the y-axis units to be %. You will also need to zoom in on the x-axis until you can see something around the 0 time mark that looks like this:
The delay needed is the difference between the time at the right peak minus the left peak time - 1 ms. For this case the result in 1.1 - 0 - 1 = .1
This is an approximation and I usually try the setting a little above and below to get the best reverse null measure. In this case, ended up using .12 ms for the stock Directiva.
