Hypex Nilai500DIY Amplifier Review
Rate this amplifier:
    Votes: 5 1.3%
    Votes: 14 3.7%
    Votes: 74 19.5%
    Votes: 287 75.5%
This is a review and detailed measurements of the Hypex Nilai500DIY class D amplifier module with PS500DIY power supply. Parts were provided by the company and member @Rick Sykora was kind enough to assemble it:
As indicated, the single channel amplifier is on the left and the power supply on the right. The amplifier has built-in preamp providing three levels of gain (12, 22 and 28 dB). A jumper selects the appropriate level. At 12 dB, you need about 12 volts to reach full power which requires a pro audio interface or a pre-amp with that level of output. The sole input in this configuration is balanced.
In use the amplifier was exceptionally solid even when pushed hard. It kept going and stayed very cool. It is rated to 2 ohm (see measurements below).
Edit: in the original review I had the top open so I could change the gain settings. Alas, it turns out that doing so allowed some noise pick up around 10 kHz. I re-tested with the lid closed and that issue went away. As a results, we have slightly better performance especially in high-gain.
Hypex Nilai500DIY Measurements
Let's start with lowest gain setting:
That is superb performance with distortion at or below -140 dB! Here is the response at higher grain settings:
With all thee gain settings, the amp lands in our top 20 best amplifiers ever reviewed based on combined noise and distortion rating (SINAD):
Noise performance is excellent but just shy of state of the art:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit SNR at 5 watts Measurements.png
But gets there at full power:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit 12 dB gain SNR Max Power Measurements.png
As we expect from Hypex, frequency response is load impedance independent:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit 12 dB gain frequency response Measurements.png
Multitone performance is excellent:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit 12 dB gain Multitone Measurements.png
Amplifier is stable on power up:
Let's look at available power at 4 ohm:
Looks like we no longer have to decided between superbly low noise and distortion and available power! State of the art performance is once again achieved in low gain while still producing lots of power (342 watts). Allowing distortion to climb to 1% naturally gives us more power (and matches company spec):
Hypex Nilai Nilai500 DIY Class D Amplifier Kit Max and Peak Power 4 ohm Measurements.png
We still have healthy power even with 8 ohm load:
Since the amp is rated at 2 ohm, I measured that as well:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit Max and Peak Power 2 ohm Measurements.png
There is a bit of penalty but still great performance. Seems power supply is limiting power so you don't get more juice.
I was a bit surprised at the ballooning of the distortion at higher frequencies:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit Power 4 ohm versus frequency Measurements.png
EDIT:
There is more of a noticeable pop on power off than power on:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit On Off Pop Noise Measurements.png
As requested, here is the switching response:
Hypex Nilai Nilai500 DIY Class D Amplifier Kit FFT switching frequency Measurements.png
It is clear Hypex is taking competition in class D amplifiers seriously responding with a DIY friend amplifier solution that has a ton of power and wonderful performance. While we could nitpick here and there, but in the larger context of the amplifiers out there, this is a superb offering of great performance and lots and lots of power.
FYI I don't have pricing for the kit. If someone has it, please post. I see online ads saying around $900 to $1,100 for a single channel.
I am happy to add Hypex Nilai500DIY amplifier and its companion PS500DIY power supply to my recommended list.
Endibol
That is superb performance with distortion at or below -140 dB! There is a bit of noise around 10 kHz which gets amplified when gain is boosted:
Multitone performance is excellent except that bit of noise around 10 kHz:
In Europe it will cost 820 euro ex VAT.
Rick Sykora
Stow, Ohio USA
This amplifier is part of Hypex’s DIYclassD brand and is priced at 820€ excluding VAT (currently about $885 US). More details can be found at:
This is a successor product to Hypex's NC400 amplifier kit and is a much-improved offering all around. Notably, it was a breeze to assemble as the instructions are very good and an animated build video has been included.
Here are external pics...
Along with a status LED, the front panel has a (smallish) standby power switch. The IEC power inlet is fused and the amp has high quality binding posts. A trigger input is included and Hypex moved the LED brightness control to the back panel. The case has been redesigned (from the previous clamshell) and allows simpler access to the internals (notably the gain jumper setting).
P.S. Should mention the other standout feature is a 5 year warranty. Hypex reports that the Nilai parts are more premium than their OEM offerings. As posted later, should have mentioned VAT in pricing, so I have updated.
kjb
What happened to the 10 kHz distortion boost at medium gain? Is it hidden in noise? In the other two measurements it is clearly visible and about as high as the second harmonics.
I noticed that as well and thought it was buried in the noise floor.
jae
It's €820 for the mono kit and €1225 for the stereo kit (250 WPC/single PSU), excluding taxes.
kjb
Just thinking, distortion at 10kHz doesn't seem to follow the gain setting. Medium gain is only 6 db lower than high gain, but the distortion at 10 kHz looks like it is as low as the 10kHz distortion at low gain, and ~20dB below the 10kHz high gain distortion. It doesn't follow the expected pattern.
I wonder what the power vs distortion at different frequencies would look like at medium gain.
Endibol
Great review, great amp!
@amirm Hope you get to test the Hypex DIYPreAmplifier kit as well (1500 euro incl. VAT).. Can't wait to see that review!
uwotm8
How exactly that amazing D-class SINAD is beinf stated at 112 dB if it turns into 80 dB pumpkin @10 kHz+?
Seems a bit tricky and yes, not this amp alone, not Hypex alone - almost all of them.
And yes again, 80 dB is okay too.
Question is if it's correct to mark such amp as a 110 dB+:rolleyes:
Waxx
Wodecq, Hainaut, Belgium
Good amp, but a serious step up for the price of the Hypex NC400 and some of the full builds that are availble of Hypex modules of similar power. Lke said you can get very good builds from Purifi modules with more power and no kit for similar prices. So the best deal arround they are not. But on it's own, it's a great clean amp like we would expect from Hypex.
