- Joined
- Sep 12, 2020
- Messages
- 336
- Likes
- 488
Great… I love cheap stuff….and I can not hear above 10,000 hz anyway. Maybe that’s why vintage good speakers only went to 15000 hz
whats a davenport....just kiddingLooks like it's maybe designed to be laid on its side and placed inside the arms of a davenport.
The f3 point there is most likely because of the THX certification requiring a 80ish hz crossover point, but its still an ortherwise good speaker as well!Its -3 dB point is 85 Hz whereas the Google Nest Audio is 60 Hz. That would make a considerable difference in the perceived audio quality.
Yeah, would be an interesting little experiment, I wonder if @amirm would measure it again without the grill? On a practical level it's fugly without the grill though, but would be interesting to see if that's what's creating the jaggedness in the treble.It is probably from the front cover. Sound bouncing around in there creating little nulls and peaks.
They'd have to come up with an exposed design or removable grill.
I'd guess they definitely don't want fingers on the drivers so exposed is out and user friendly removable grill is not really a desired trait for this type of speaker by buyers.
We are stuck with these effects.
I wonder how it measures with that front cover off.
Adding a subwoofer is relatively easy: find a long-discontinued Chromecast Audio dongle (might cost as much as the speakers) and plug it into the sub of your choice. Then add it to the group w/ the Nest Audio on the Google Home app.Thanks for your review Amir.
Two Google Nest Audio Speakers and, if a sensible solution can be achieved, together with subwoofers plus integrated with a smart TV might be something?Preferably if it would be possible to EQ (at least the subwoofers in that case). Maybe that's asking too much?
When I built my HT setup, the one thing I couldn't do was add true rear speakers. I would love to use a pair of these on my kitchen counter (behind me when I am in the sweet spot), but I can't figure out how to feed them just the rear channel signals from my HT receiver. Does such a solution exist?This is a review, teardown, detailed measurements, listening tests and EQ of Google Audio Nest "smart" streaming speaker. It was kindly drop shipped to me by a member. List price is US $99.99 but I see it as low as US $65.
While not very unique in its looks, the Nest Audio nicely fits in the category with the obligatory gray fabric cover. Four or five LEDs shine through the fabric when on. When idle, they are orange but otherwise white. It shows the current volume among other things. Back side shows the plug for the 24 volt/125ma power supply and a hard switch to turn the microphone off:
I read that Google went all out with designing their own simulation tools and even conducting double blind listening tests in the process of developing this speaker! It shows when pry off the front cover:
Some kind of cast metal (aluminum?) contains the drivers. The tweeter has a built-in wave-guide courtesy of that shell. The 6 rubber screws/mounts provide acoustic suspension.
It was non-intuitive to use "Google Home" to configure the speaker. Configure I did using my phone and it all went nicely although I was annoyed by myriad of questions including what my address is! Firmware was updated and the speaker came alive and warned me in a nice female voice that the microphone was turned off. It did that on the next power cycle. I guess they want to avoid support calls for people who like me, thought the switch was for power and not microphone!
Speaking of power cycle, after that, I could not get Google Home to reliably connect to the device and let me change its volume. Roon player however, recognized it through Chromecast protocol and nicely let me change volume control there.
Google Nest Audio Speaker Measurements
Let's start with our standard anechoic frequency response measurements:
I could not believe my eyes when I saw that super smooth bass, midrange and lower treble! It is almost ruler flat with excellent directivity. Some kind of complex interaction occurs between drivers above that causing those jaggies. Fortunately our hearing bandwidth resolution shrinks as frequencies go higher, making us much less sensitive to those variations. To wit, here is the same graph but with 1/10 octave smoothing (instead of standard 1/20th):
There is still a deep trough post 10 kHz in on-axis response which may be due to some diffraction.
Note that I have read there is a bass limiter that reduces bass peak as you crank it up. I meant to test the speaker at my standard 86 dBSPL but somehow it switched down to 80. You can see the slight hump around 100 Hz which is fine in my book.
Good directivity results in good early window response:
Predicted in-room response is smooth as a result with some exaggeration of treble frequencies:
Beamwidth is rather wide which is good for a lifestyle speaker with just front firing drivers:
Vertical directivity likewise allows a bit of elevation change without the response varying a lot:
It is a pain to test these streaming speakers so I only ran one distortion test:
This is quite good for this tiny speaker!
Finally here is the step response:
Google Nest Audio Speaker Listening Tests and EQ
My first standard reference track sounded surprisingly neutral! It was as if I was listening to a small studio monitor. Further listening and cranking up the volume a bit more, resulted in perceived brightness. A single filter cured that nicely:
There is naturally no low, low frequencies. That made music that relied on that sound flat. Otherwise, even techno music sounded good to excellent. Speaker does an excellent job of keeping distortion at bay even at max volume. Then again, it doesn't get very loud by "normal" speaker standard.
Amazing what happens when you apply proper engineering and science to even a tough problem. Small, lifestyle speaker that sells for next to nothing which teaches many speakers what good design is like! Objective performance is excellent up to a few kHz after which it gets a bit wiggly. Subject performance, sans a bit of brightness, is better than anyone deserves in this category. And let's remember this is a streaming amplifier with all the features that come with that and not just a passive box!
I am going to recommend the Google Nest Audio speaker. Someone cared that we get good sound even in this category product.
RCA to Bluetooth adapters are available, though I'm not sure how it would work. But it might be worth a try.When I built my HT setup, the one thing I couldn't do was add true rear speakers. I would love to use a pair of these on my kitchen counter (behind me when I am in the sweet spot), but I can't figure out how to feed them just the rear channel signals from my HT receiver. Does such a solution exist?
Even if you figured out how, the speakers will gave high levels(noticable) of latency.When I built my HT setup, the one thing I couldn't do was add true rear speakers. I would love to use a pair of these on my kitchen counter (behind me when I am in the sweet spot), but I can't figure out how to feed them just the rear channel signals from my HT receiver. Does such a solution exist?
Thanks. I know about the latency issue. In theory, I think Dirac Live can compensate, but does anyone know if the latency is consistent enough for that to work well? And can this Google speaker pair with any app/BT transmitter, or is it a walled garden system?Even if you figured out how, the speakers will gave high levels(noticable) of latency.
There are other choices that use wifi that may work, if your Receiver has rca outputs.
Maybe try Parts Express or Amazon?
Connect the wifi transmitter to the rear rca outputs, connect the wifi receiver to a set of active speakers on your counter.
These were the 1st ones to show on Amazon search, just to start with.
It is really easy to open this speaker and disconnect the lights. So when the mic is turned off you will not see the orange lights.Turn off the microphone and isolate the speaker from the web via parental controls or similar. I do that with my older iPads I exclusively use as Roon displays
These can work visa normal Bluetooth but do require the Google Home to do the setup/pairing which is a bit of a clunky process and (in my experience) not totally stable connection.Thanks. I know about the latency issue. In theory, I think Dirac Live can compensate, but does anyone know if the latency is consistent enough for that to work well? And can this Google speaker pair with any app/BT transmitter, or is it a walled garden system?
Seriously? Setup, I understand - but pairing? You need the Google Home app to pair these with Bluetooth?These can work visa normal Bluetooth but do require the Google Home to do the setup/pairing which is a bit of a clunky process and (in my experience) not totally stable connection.
You need the Google home App to setup and pair two speakers in one stereo system once. After that you can just say "okay Google pairing Mode" and you dont really need the App anymore. Or just chromecast any app like Spotify or Tidal.Seriously? Setup, I understand - but pairing? You need the Google Home app to pair these with Bluetooth?
Does anyone use these with iOS?
Ok, I did not make myself clear enough. I want to avoid the app and the microphones even more so, just Bluetooth. Maybe I am just naive. ;-)You need the Google home App to setup and pair two speakers in one stereo system once. After that you can just say "okay Google pairing Mode" and you dont really need the App anymore. Or just chromecast any app like Spotify or Tidal.
No chromecast on ios as far as i know.Ok, I did not make myself clear enough. I want to avoid the app and the microphones even more so, just Bluetooth. Maybe I am just naive. ;-)
About Chromecast, that does not work on iOS, does it?
Google's own iOS Apps support Chromecast where applicable.About Chromecast, that does not work on iOS, does it?
