Denon Replaces AKM AK4458 DAC IC in X4700H and X6700H
The DAC choices are pretty questionable. It seems they wanted to meet the price point they had with AKM. ESS and TI have better DACs to meet the old AKM specs but they didn’t go for performance parity.
I’m aware we are splitting hairs here, 13 db difference probably won’t be audible, but the HDMI 2.1 disaster should have told them that their audience cares about little details as well. The HDMI issue affected maybe less than 5% of their audience, but the DAC choices affect 100% of their audience.
Their financial reserves to deal with problems has probably been eaten up by the HDMI issue, I highly doubt Nuvoton compensated 100% of the expenses they had.
The reviews have already been written. The average buyer will have no idea that parts and specs have been changed. I'm sure Denon/Marantz are not concerned in the slightest.
Thanks. Is there a URL with measurements?
Right here on ASR, the 3500, 3600, 3700, 4700, 6700, 8500, 6014, 7015, 7705, all before the DA board change have been measured, but none of those with the different DA boards have been reviewed/measured yet. The AV8805 (AK4490), and AV8805A (ES9010K2M) have also been measured, there results for those two were comparable despite the lower spec of the ES9010K2M is not a factor, most likely because in those cases the DAC IC itself is not the limiting factor.
Marantz AV8805A Review (AV Processor) | Audio Science Review (ASR) Forum
Thanks. I'm specifically interested in the 3700 v2. Hopefully the same logic applies, but it doesn't seem safe to assume that they put the same effort into their mid-range receivers.
So have we seen any comparisons between the new and old DACs? I've just ordered the new post may X4700H and feel a bit worried
I bought my Denon 4700 in Sept 2020 for $1529. I'm pretty amazed they retail for $1999 now. The good thing is they seem to be back in stock. I doubt you will notice a major difference with the DAC change. What I really like about the 4700 is the ability to use pre-amp mode with external amps and the option for Auto 3D. However, with the Denon 3700 price now $500 lower the decision to go with the 4700 becomes a little more difficult. Have fun!
Ahhh I see, well for me in the UK the difference was not that large, also doing part exchange of to old receiver the x4700h cost me the same as x3700h.
It wouldn't be too bad if they use something like the ES9006. You an see the comparison between the 8805 (AK4490) and 8805A (ES9010), very comparable, but it is unlikely for them to use the ES9010 in the X4700H.
Not sure if this was mentioned here, but the HDMI bug was also fixed in the updated line:
https://www.whathifi.com/news/denon...s-built-since-may-are-free-of-the-hdmi-21-bug
Make sure the serial ends with numbers from 70001 onwards, which means that the AVR has both ESS DAC and newer bug-free HDMI chip.
How would you "make sure" of that? I have no way of knowing the serial number prior to receiving the item.
I don't understand why they haven't renamed the fixed versions, similar to 8500H -> HA.
I emailed my retailer before and asked them to check. They at least said the one I will be getting will be of the new post May batch.
A good rule of thumb is the date manufactured. If it was made in 2021 it will have the HDMI fix and the "new" DACs.
I bought my Denon 4700 in Sept 2020 for $1529. I'm pretty amazed they retail for $1999 now. The good thing is they seem to be back in stock. I doubt you will notice a major difference with the DAC change. What I really like about the 4700 is the ability to use pre-amp mode with external amps and the option for AURO 3D. Hoever, with the Denon 3700 price $500 lower the decision to go with the 4700 becomes a little more difficult. Have fun!
I bought my 4700 in May of 2021 for $1399, i'm so glad I didn't wait till CEDIA 2021 to see what the new models that where never announced would look like. I'm feeling pretty good about my decision now, because my biggest concern with the 4700 was it only having one HDMI 2.1 input but they have come out with a 3 port 2.1 switching box that's controlled by the AVR so now I don't think I'll need a new AVR for a long time. I don't think they'll be coming out with the new xX800h models till 2022 so it's going to be awhile.
I have had a Denon AVR-X3700H sitting boxed since the end of February this year (problems moving house has prevented me from using it) and I am unsure if it would have the lesser quality DAC. This is it's serial number DBCG122012822. Does this serial number contain a manufacture date?
Pretty sure that was manuf in Dec 2020, so it is almost certainly using the original AKM DACs since the fire occurred in Nov 2020. It seems replacement DACS started hitting in 2021.
In my naivete :) I simply sent a question to Marantz and Denon via their web sites. FWIW this is what I received back:
Denon:
Thank you for contacting Denon Support, we value you as a customer and appreciate the opportunity to be of assistance!
The DAC of AVR-X8500HA is AK4490 , while the AVR-X6700h is AK4458
If you have any further questions please feel free to contact us again.
Thank you for contacting Denon Customer Support. Have a great day!
Still waiting for the reply from Marantz...
Denon:
As I mentioned before, Denon tech support, for some reason has not been very good or useful (in my experience). In this case, their response would be correct for the models made in 2020. For units made in 2021, depending on the manufacturing date, some will have different DAC chips than the 4490 and 4458, so their response is almost useless. Let's wait for Marantz, who (again just in my own experience) seemed to give more informative answers.
I doubt I'm going to hear from them... :rolleyes:
