- Thread Starter
- #21
Stuff needs to get reviewed at some point. In addition, my back is hurting so I opted for a lighter, smaller speaker to test.Curious, how come you review such a junk in last 3 reviews?
This products does not earn any attention.
Too expensive at $1000+ for me to buy it. Hopefully someone sends one in for review.Anyway would love to see a Deff Tech D11 in here. That one gets high subjective reviews and is pretty looking as well.
To make sure I was not in a lousy "bad sound mood," I replaced the ProMonitor 1000 with the Pioneer SP-BS22-LR speaker. Wow, what revelation!
The ununiformed rear of the cabinet appears to be a poor example of plastic molded injection (am I seeing this right?). The price per pair is incredibly disappointing.
That seems like the charitable interpretation, designed as wall mount rears crossed over to a sub, but as @Francis Vaughan points out, just using a simple sealed box would be a better and cheaper solution.EDIT: I wonder if it's been designed to sit really close to walls or in corners, which might pump up the bass and bring it more in-line with the treble....someone in this thread did mention that there were some rear panel design ques that indicated wall mounting as a feature.
What I find hilariously shameless is the manual has multiple sections talking about crossing over with the ProMonitor sub; not any sub, but their sub specifically. Don’t know if I’ve ever seen that.So maybe I guess the manufacturer's response to this would be: "Thou shalt not use it nor measure it without a sub"![]()
-3dB down at 100Hz with a 5.25" Woofer. Why?
You'd need something like 150Hz crossover frequency with this, why would they do that?
Yes it works - the "middle screw tuning" prevents the speaker to fall apart in higher SPLs. Also rather than producing bass it acts as a suspension to supress even more resonances.It's get even stranger to have a passive membrane in it. I realy wonder what it does in this speaker? Does the membrane even work?
Yeah, true, and you'd think if companies designed a speaker for a specific use or placement then they might refer to this in their sales blurb to make sure it was bought by the right people for the right implementation. (I'm not sure many companies are upfront about saying that their speaker needs to be close to a wall for best performance though, but still if it's designed for that purpose then I'd want my customers to know that).That seems like the charitable interpretation, designed as wall mount rears crossed over to a sub, but as @Francis Vaughan points out, just using a simple sealed box would be a better and cheaper solution.
