CHORD M-Scaler Review (Upsampler)
Rate this product:
    Votes: 358 88.2%
    Votes: 13 3.2%
  • 3. Fine (happy panther
    Votes: 7 1.7%
    Votes: 28 6.9%
solderdude
The Neitherlands
At 325 hz? Not likely. I know it is a log scale, but it looks short of 360 hz.
What is weird about that particular plot is that there appear to be no 1kHz harmonics. All of the harmonics appear not to be 1kHz multiples.
All other plots show expected harmonics. Something is fishy there.
xaviescacs
La Garriga, Barcelona
Wow! Still three people voted for great :D
The poll just says "Rate this product", not "Rate this product according to its measured performance".
Purité Audio
Industry Insider
Barrowmaster
London
Enlightening as always, despite dubious integrity Rob Watts’ designs are usually competent, clearly not in this case.
sq225917
Surely there must be something on the underside of that pcb? Like fantastic thermally controlled clock circuits, digital out buffers that are immune to PS noise, thighs of sun tanned virgins for rolling the cigars that Rob Watt is smoking when he's not on crack?
It's almost as if ZF are given about the quality of the digital outputs.
BeerBear
What's the theoretical benefit of upsampling?
Better anti-imaging filtering compared to your DAC (at the cost of some extra latency).
But you can upsample for free in software, so I don't really see the point of devices like these. Well, I guess it could make sense if you're not using a computer for playback...
chris719
Simple 2 layer board with non audio grade caps .....
How can you tell? You don’t even know what you’re looking at. It’s almost certainly a 4 or 6 layer board because on the bottom side is a Xilinx Artix 7 FPGA. You can’t route one on a 2 layer board, period. Audio grade caps are a scam and I see appropriate components here.
Blumlein 88
Actually, I voted "Not terrible" :cool:. If it does nothing, it can't be poor. :p There is always room for different opinions, states of mind and purposes. :)
Different opinions for sure. If it does nothing for $1 million, I'd rate it poor. I mean $5k can treat your room really well, or buy lots of music or concert tickets, or a really good speaker upgrade, etc., etc.
xaviescacs
That looks like a marketing claim from the company. ;) What about a difference in the final analog output?
Blumlein 88
No it really gives better steeper anti-imaging, but so can software upsamplers. So yes, they do change the analog output.
Sokel
Does anyone care to hypothesize about why the Topping DAC was so much worse? Is that due to the massive jitter that the SPDIF receiver just can’t deal with?
Isn't the jitter rejection one of the virtues of a good DAC?
Something is very wrong here.
BeerBear
The difference is there. You can also see it in this review.
But the real question is whether it provides an audible improvement or not. And that's not something we can answer definitely. Every person can answer it for themselves with a blind test.
EDIT: Of all the things to "worry about" in an audio setup this one ranks very very low, to the point that IMO you can safely ignore it. But I remain open-minded in case someone eventually proves that there is an audible benefit.
xaviescacs
I'm always unsure about taking cost into account when answering this polls. For the majority of people, if cost is a variable, almost everything tested on this forum is too expensive and useless. I'm inclined towards not taking price into consideration (when voting xD), it's a relative thing. Some homeless bankrupted audio enthusiast living below a bridge and reading this forum will always vote poor then, no matter the performance...
solderdude
The Neitherlands
There will have to be a lot of buried vias to accomodate for a BGA on the bottom side so lots of layers would be needed.
anphex
Berlin, Germany
Uuh...
chris719
You can do an Artix 7 without blind or buried vias if you choose the largest pitch package (0.8mm I think). Not sure what he’s using. Either way I agree with you, it’s definitely not some simple 2 layer board.
I included audio samples. Can you tell the difference between them?
