I'm doing my best not to waste any time talking about measurements and my first post had nothing to do with that.You may find it helpful if you read this post before wasting to much keystrokes.
Then why the question and talk about error correction and network is better than USB?Most likely nowhere, unless there is a problem.
There are 203 posts on this thread and you are not the OP. It will help if you linked that post you mention.I'm doing my best not to waste any time talking about measurements and my first post had nothing to do with that.
I didn't state an opinion - I just asked a question. If he heard no difference with 2x then one more button press would have given 4x, so he would have gone from what he perceived as no difference at 2x to the next highest setting. With a TT2 that was where I noticed the difference became evidence - at 4x.you misunderstand…..I am not saying that you are putting anyone’s opinion down……I am questioning your opinion….. @amirm only used 2x upsampling so he could instantaneously switch from no upsampling to upsampling active. You cannot go instantaneously to 4x or 16x….
My first post in the thread was basically asking why he only conducted the listening test with 2x upsampling when he could also have tried 4x and 16x.There are 203 posts on this thread and you are not the OP. It will help if you linked that post you mention.
The files were bypassed and 2x - not 16x or 4x and he didn't try listening with 4x or 16x, which was what I was questioning.OK, I think I see your point. Sounds like had the reviewer posted a 16x upsampled file to listen as well as the original sample for comparison it would address your issue.
He thought there is no reason in his own mind, he doesn't value listening tests, he didn't think of it, he didn't have the time, he wanted to tend to his garden instead, etc., etc. Take your pick...I didn't state an opinion - I just asked a question. If he heard no difference with 2x then one more button press would have given 4x, so he would have gone from what he perceived as no difference at 2x to the next highest setting.
What a strange and somewhat aggressive response to a simple question. Relax buddy, there's no need to be quite so defensive.He thought there is no reason in his own mind, he didn't think of it, he was lazy, etc., etc. Take your pick...
You seem to forget that he is doing it as a hobby. He is not charging for these tests. However, you are critiquing him as why he didn't push a button?
May I suggest you start helping the forum by becoming a donor and then critique the tests.
And what's with this quaint term "D/A processor" he still uses when the rest of the planet calls it a DAC?
Because shit happens? I did not say network is better, I said they are getting momentum. In the case of this product, there is obviously a problem, we don't know if it's Jitter, noise, or corruption and rounding error in the resampling process. Or maybe you do? The comment was "DACs should be immune to what happens prior." My point is no, it's not.Then why the question and talk about error correction and network is better than USB?
Thanks, but most call the complete product a DAC, and the actual converter the DAC *chip*. No consumer buys the naked chip.I use "D/A processor" for a complete product that incorporate a D/A converter - "DAC" - chip or circuit.
John Atkinson
Technical Editor, Stereophile
Here brick wall filter attenuation is more than 120db while in amir's measurements it is 80db. did I get anything wrong ? The main idea behind m scaler is filtering and if it is 120db brick wall attenuation then it is ok i think.Chord Electronics Hugo M Scaler upsampling digital processor Measurements
Sidebar 3: Measurementswww.stereophile.com
Is this the same model?
Isn't the actual M Scaler needed to be heard in person if we are going to hear the full effect of the upscaling?I included audio samples. Can you tell the difference between them?
According to Google there are about 420m entries for "D/A processor" and 370m for "DAC".Thanks, but most call the complete product a DAC, and the actual converter the DAC *chip*. No consumer buys the naked chip.
I am not sure I want to know the resultCan you redo full Hugo2 measurements?
You did it long time ago right after getting your AP
I imagine you're testing is better now than then
Well, colour me surprised.According to Google there are about 420m entries for "D/A processor" and 370m for "DAC".
